Seagate Exos 1.2TB E-Class Mission Critical SAS 2.5" 10K 512
Quicklinx: DDWHWS00 Mfr#: ST1200MM0129
£217.91 ex VAT
£261.49 inc VAT
The Seagate Enterprise Performance 10K HDD is an ideal 1.2 TB hard drive for mission critical applications. It delivers best-in-class mission critical random performance, highest capacities and the low power that data centers need to meet demanding service level agreements and to keep up with data growth and reduce IT operating costs.
Seagate Exos 10E2400 ST1200MM0129 - hybrid hard drive - 1.2 TB - SAS 12Gb/s
Hybrid hard drive - internal
1.2 TB
Flash Memory Capacity
16 GB
NAND Flash Memory Type
Enterprise multi-level cell (eMLC)
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
256 MB
Spindle Speed
10000 rpm
PowerChoice, Protection Information (PI), Seagate RAID Rebuild, Instant Secure Erase (ISE), advanced format 512e, advanced format 4Kn, Intelligent NAND Endurance Management, Seagate Fast Format
70.1 mm x 100.45 mm x 15 mm
230 g
5-year warranty
1.2 TB
16 GB
2.5" SFF
SAS 12Gb/s
Buffer Size
256 MB
70.1 mm
100.45 mm
15 mm
230 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
270 MBps
Average Latency
2.9 ms
Spindle Speed
10000 rpm
Reliability
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Power Consumption
7.15 watt (active) , 3.91 watt (idle)
ISO/IEC 27040:2015, NIST SP800-88
Limited warranty - 5 years
5 °C
55 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
40 g @ 11 ms
Shock Tolerance (non-operating)
400 g @ 2 ms
Vibration Tolerance (operating)
0.5 g @ 0-500 Hz
Vibration Tolerance (non-operating)
3 g @ 0-500 Hz
Type: Hybrid hard drive
Brand: Seagate
