AegisSAN Q500-P10 is the cutting-edge storage system designed to help users do more with less with the top-notch hardware configurations, dual active controllers, fully modular components as well as the state-of-the-art software functions.
AegisSAN Q500-P10 features six 1GbE iSCSI ports and one 1GbE management port to provide high availability & great performance for enterprises and SMB.
QiSOE (Qsan Hardware iSCSI Offload Engine)
AegisSAN Q500 iSCSI series system features QiSOE (Qsan hardware iSCSI offload engine), which adopts a dedicated CPU core to process iSCSI packet. With QiSOE the performance will be booming up dramatically. -
Virtualization technologies
Virtualization refers to the creation of a virtual machine that acts like a real computer with an operating system. It adds a new layer of software and hardware between storage systems and servers so that applications no longer need to know on which specific drives, partitions or storage systems their data resides. This greatly enhances the flexibility, agility, scalability and manageability. AegisSAN Q500 storage system supports virtualization technologies of VMware, Citrix and Hyper-V enabling improved performance, superior scalability and better agility in the highly virtualized working environments. -
Hardware redundancy
Qsan storage systems are equipped with fully redundant components for all major functions, including dual active RAID controllers, power supplies, fan modules, battery backup modules, and SAS JBOD expansion ports. Being hot-swappable, all of them enable non-stop services for enterprises.
- Qsan AegisSAN Q500-P10-D212 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 2U
- Total Array Capacity
- 36 TB
- Interface
- iSCSI (1 GbE)
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- Supported Drives
- SATA-600 / SAS-2
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
- Storage Controller Quantity
- 2
- Hard Drive
- 12 x 3 TB HDD - hot-swap
- OS Required
- SunSoft Solaris 10, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Microsoft Windows Server 2012, SunSoft Solaris 11, Microsoft Windows XP / 7
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- 44.6 cm x 49.95 cm x 8.8 cm
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- 12
- Supported Devices / Modules Qty
- 12
- Supported Drives
- SATA-600 / SAS-2
Storage
- 36 TB
- HDD Array External Interface
- iSCSI (1 GbE)
Storage Controller
- RAID (iSCSI)
- Installed Qty
- 2
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- Cache / Buffer Size (Max)
- 8 GB (installed) / 16 GB (max)
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Storage Controller (2nd)
- Installed Qty
- 2
Hard Drive
- HDD - hot-swap
- Capacity
- 12 x 3 TB
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap
- 12 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 1000Base-T (management) - RJ-45
- OS Required
- Built-in 2 cooling fans, hot-swappable fans
- UL, BSMI, cUL, FCC, RoHS
- Power Device
- 2 x internal power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- Power Provided
- 400 Watt
- 80 PLUS Certification
- 80 PLUS
- Power Factor Correction
- 44.6 cm
- 49.95 cm
- 8.8 cm
- Limited warranty - 3 years , Limited warranty - battery - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
