Brand
Poly Plantronics PSP EHS Cable for Savi and CS Range 2.5mm to 2.5mm
Quicklinx: 854FWS00 Mfr#: 84757-01
£16.72 ex VAT
£20.06 inc VAT
Complement your Plantronics CS500 or W700 series wireless office system by using an electronic hook switch for remote call answering and call ending.
Compatible with the Following Panasonic Telephones:
  • KX-UT133
  • KX-UT136
  • KX-UT670
  • KX-UT248
Electronic Hook Switch- communicates electronically with the phone
Eliminates the need for a HL10 lifter
Enables One Touch Remote Call/Answer with Plantronics Headsets
Poly Panasonic PSP EHS Cable - headset cable
Cable
Headset cable
Savi W740, W740-M
Cable Type
Headset cable
Poly Savi W740, W740-M
Brand: Poly
