StarTech.com Premium Certified HDMI Cable 1m
Quicklinx: J1K4WS00 Mfr#: HDMI2-CABLE-4K60-1M
22 In Stock
£5.21 ex VAT
£6.25 inc VAT
The 1 m (3.3 ft) Premium Certified High Speed HDMI Cable from StarTech.com offers performance designed to meet the demands of high-definition audio and video. With support for 4K at 60 Hz, this HDMI cable ensures crisp visuals and immersive sound, making it an ideal choice for gaming, streaming, or connecting to your home theater system. Built with aluminum mylar foil shielding and a thermoplastic elastomer jacket, it provides durability and effective EMI protection against interference, ensuring a stable connection at all times.
This HDMI cable is equipped with technology features, including HDMI Ethernet Channel (HEC), Audio Return Channel (ARC), and HDR 10 support. With a data rate of 18 Gbps and the ability to transmit up to 32 audio channels, it delivers a rich audio experience while accommodating various devices. The strain relief feature enhances flexibility, while the gold-plated connectors ensure signal quality, making this cable a reliable addition to any entertainment setup.
  • Performance
    The cable supports 4K 60 Hz resolution, ensuring a clear and crisp picture quality when connecting high-definition devices.
  • Shielding
    Built with aluminum mylar foil and braid, this cable minimizes electromagnetic interference for a stable and reliable signal.
  • Audio capabilities
    With support for 32 audio channels, this HDMI cable allows for a rich, immersive sound experience in home theater systems.
  • Construction
    The thermoplastic elastomer jacket offers flexibility and durability, while the strain relief feature enhances the cable's longevity.
  • Data transmission
    Boasting a data rate of 18 Gbps, this cable ensures fast and efficient transmission of both audio and video signals.
StarTech.com 1m (3.3ft) Premium Certified High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 1 m
Cable
Premium High Speed - HDMI cable with Ethernet
American Wire Gauge (AWG)
30
Length
1 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K60Hz support, passive cable
Cable Type
Premium High Speed - HDMI cable with Ethernet 4K60Hz support, passive
30
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
1 m
Plated Connector
Gold
18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDR 10 support, 32 audio channels, cable diameter 6 mm, strain relief, EMI protection
Connector
19 pin HDMI Type A - male
RoHS, HDCP 2.2, halogen-free
Limited warranty - lifetime
