Cables Direct 3m SVGA M-F Extension Connected BL
Quicklinx: C908WS00 Mfr#: CDEX-803K
Length: 3m
£4.54 ex VAT
£5.44 inc VAT
Our range of Super VGA cables are constructed using UL2919 approved 28 AWG triple mini coaxial and 4x 28 AWG conductor cables, this allows them to be used for extended distances. Triple shielded with copper braid, foil and drain wire. This range of cables have all pins connected and should work with widescreen monitors that require DDC cables. The DDC link is carried on three pins 12, 15 and 10 (data, clock and ground) in a 15-pin VGA connector.
Cables Direct VGA extension cable - 3 m
VGA extension cable
Triple shielded coaxial
Drain wire
Length
3 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
UL 2919, DDC
VGA extension cable
Shielding Material
Foil with copper braid
American Wire Gauge (AWG)
28
Drain wire
Length
3 m
Connector
15 pin HD D-Sub (HD-15) - female
UL 2919, DDC
Length: 3m
Brand: Cables Direct
