StarTech.com 2m High Speed HDMI Cable with Ethernet - HDMI to HDMI Mini- M/M
Quicklinx: 87MWWS00 Mfr#: HDACMM2M
19 In Stock
£12.91 ex VAT
£15.49 inc VAT
Connect an HDMI Mini-equipped camera, Smartphone or portable device to your HDMI-capable TV or display. The HDACMM2M HDMI Mini to HDMI Cable with Ethernet lets you connect devices that feature an HDMI Mini port to an HDMI-enabled display/device, providing a cost-saving solution for connecting cutting-edge and next-generation HDMI-enabled devices to existing HDMI technology.
This HDMI Mini to HDMI adapter features high-quality gold-tipped connectors that ensure peak connectivity.
  • High-quality shielding
    The cable features aluminum mylar foil with braid to minimize interference and ensure smooth signal transmission, making it ideal for high-definition content.
  • Durable connectors
    The 19-pin HDMI Type-A and mini HDMI Type-C connectors are gold-plated, which enhances conductivity and provides corrosion resistance for long-lasting use.
  • Enhanced functionality
    This HDMI cable includes an HDMI Ethernet Channel (HEC) that allows for network functionality between devices, helping to reduce the number of cables needed.
  • Environmentally compliant
    Designed to meet RoHS standards, this cable is made with materials that are safe for the environment, supporting eco-friendly practices.
StarTech.com 2m High Speed HDMI Cable with Ethernet HDMI to HDMI Mini - HDMI cable with Ethernet - 2 m
Cable
Shielded
American Wire Gauge (AWG)
30
Length
2 m
Connector
HDMI - male
Connector (Second End)
19 pin mini HDMI Type C - male
Cable Type
Shielded
30
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
87MW StarTech.com 2m High Speed HDMI Cable with Ethernet - HDMI to HDMI Mini- M/M In Stock £12.91
87MW StarTech.com 0.5m High Speed HDMI Cable with Ethernet - HDMI to HDMI Mini- M/M In Stock £5.55
87MW StarTech.com HDMI Coupler / Gender Changer - F/F In Stock £8.59
