Philips Hue White Ambiance Single Bulb (B22)
Quicklinx: CJ01WS00 Mfr#: 929001200202
Select:
  • B22
Create your ambience
Set the right ambience for any moment with a range of beautiful, natural white light. Use the app to set any shade of white light, from cool energizing daylight to relaxing warm white light. Take control and set the ambiance. Not too bright. Not too dark. Just right.
Wake-up naturally
Ease your sleeping routine and wake up gently for a fresh start of each day. Philips Hue will help get you out of bed in a nice way. The gradually increasing light intensity gives you the feeling you are waking up naturally with sunlight - rather than the rude awakening of an alarm ringing.
Boost your energy levels
Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind. Perfect for those moments when you need a kickstart or when your batteries are running low.
Light for your well-being
Light influences our mood, behavior, alertness and routines. Through the app, you can set the light that is optimal for your moment. Philips Hue helps you to energize, concentrate, read and relax. Customize your daily routines into moments you can enjoy. Feel different. Feel better.
Expand your ecosystem
You can connect up to 50 lights and 7 Hue dimmer switches to the Philips Hue bridge (included). Simply begin with any of the available starter kits and start adding Philips Hue products. You can then control your lights at the swipe of a finger with the intuitive Philips Hue app for iOS and Android smart devices. Philips Hue is based on ZigBee, a low power, safe, and reliable technology to control your lights. New features and improvements are continuously added to the system. Updates to both software and firmware are done wirelessly and seamlessly directly to your Philips Hue product
Reading
Put your feet up and relax with a soft glow of white light for the perfect end of the day. Relaxing white light will help you to unwind in the evening and sleep better at night.
What's in the box?
  • 1x Philips Hue White Ambience Single Bulb
  • Wake up gently to your personal sunrise
    Ease your sleeping routine and wake up gently for a fresh start each day. Philips Hue will help get you out of bed in a nice way. The gradually increasing light intensity gives you the feeling that you are waking up naturally with sunlight - rather than the rude awakening of an alarm ringing.
  • Get ready for the day
    Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind. Perfect for those moments when you need a kick-start or when your batteries are running low.
  • Enjoy a perfect read
    Lose yourself in your favorite novels for hours on end with Philips Hue. It gives you the right white light for a perfect read.
  • Unwind with warm white light
    Put your feet up and relax with a soft glow of white light for the perfect end to the day. Relaxing white light will help you to unwind in the evening and sleep better at night.
Philips Hue White Ambiance - light bulb
Light bulb
Light bulb
