Philips Hue Appear Wall Light Inox 2-Pack
Quicklinx: H4W3WS00 Mfr#: 919313000058
Type: Wall lamp
Compatible With: Alexa, Apple HomeKit, Google Assistant
10 In Stock
£249.99 ex VAT
£299.98 inc VAT
The Appear wall light offers 16 million colours of subtle yet powerful light, by directing its beams both up and down, creating a sharp, directed triangle of light against the wall of your front or back patio.
  • 16 million colors
    Personalize your home for your perfect ambience with over 16 million colors.
  • Unique architectural light shapes
    Create an architectural focal point with outdoor fixtures that offer razor-sharp, triangular light effects against any wall or surface.
  • High-quality inox and superior synthetics
    The products are specifically made for outdoor use, utilizing high-quality materials to ensure optimal performance in outdoor conditions. Additionally, they are designed with the smart use of materials to optimize radio frequency.
  • Come home to a house filled with light
    Set your Philips Hue app to recognize when you're almost home. Before you even step out of your car or walk up the path, your selected smart lights turn on automatically.
  • Unwind with warm to cool white light
    Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax.
  • Weather-proof (IP44)
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance.
Philips Hue Appear - wall lamp - LED x 2 - 8 W - 16 million colours/warm to cool white light - 2000-6500 K - inox (pack of 2)
Wall lamp
Recommended For
Balcony, patio, porch
Light Source Type
2 x LED
Packaged Quantity
2 (specifications are for single item)
Dimmer
Inox
Wattage
8 W
Energy Efficiency Class
G
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
710 - 1180 lumens
Intelligent Assistant
Google Assistant, Alexa, Apple HomeKit - indirect
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Wall lamp
Recommended For
Dimmer
Weatherproof, outdoor usage, protection class I
Light Source
2 x LED
Built-in LED Lamp
Wattage
8 W
G
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
710 - 1180 lumens
Lifetime
25000 hours
Light scheduling, app-controlled, weatherproof
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Compatible Application
Philips Hue App
Voice Controlled
Indirect
Product Material
Stainless steel body
Body Colour
Inox
IP44
Warranty
2 years
8.4 cm
11.7 cm
24 cm
Type: Wall lamp
Compatible With: Apple HomeKit
Brand: Philips
