Philips Hue Outdoor Sensor
Quicklinx: H4V3WS00 Mfr#: 929003067401
Type: Sensor
Compatible With: Cortana, Alexa, Google Assistant
£38.92 ex VAT
£46.70 inc VAT
Control your outdoor lights automatically with a Philips Hue outdoor sensor. Place the battery-powered, completely wireless sensor anywhere - and then simply walk past to trigger your lights.
  • Wireless installation
  • Battery powered
  • Weatherproof
  • Automates your lights
A warm welcome, every day
Experience the comfort of your lights turning on automatically when you get home. Unpack your car, enter your house, all with the convenience of your outdoor lights. Having friends over? Welcome them with lights gently switching on as they approach the front door.
Installed in a matter of minutes
The outdoor sensor is easy to mount and fully wireless. So you don't need an electrician to have it installed. Just unpack the sensor, set it up through the app and install it wherever you like. Configuring the sensor and setting the daylight and motion sensitivity is also done via the Philips Hue app.
Place it where you want
The kit comes with different mounting components so you can mount it on a flat wall, or on the inner or outer corner of a wall or post. You can also mount it on a pole or drain pipe. So it's perfect for your front garden, around your door, the garage or any place around your house where it matters.
Requires a Philips Hue bridge
Connect your Philips Hue lights with the Bridge to control your lights from your smart phone or tablet via the Philips Hue app. Or control your Philips Hue lights with the Philips Hue dimmer indoor switch for on/off and dimming functionalities.
Resistant to all weather conditions
This Philips Hue outdoor sensor is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. This lamp is designed with IP54: it is protected against water splashed from any direction. The product will withstand heavy rainfall and other weather conditions.
Scare away uninvited guests
Thanks to the large view angle and detection range the outdoor sensor will spot any movement near your home. It can directly turn on your outdoor lights to expose uninvited guests in the light. You can set the indoor lights to turn on so it looks like you're home, even when you're not.
Automatically turn on the lights you want
The outdoor sensor turns on your Philips Hue lights automatically when somebody passes by, outdoor and indoor. By connecting the sensor to your bridge via the Philips Hue app, you can choose which lights go on, even inside your house. Also choose the scene or light setting that should be triggered. The integrated dusk-to-dawn sensor ensures your lights only switch on when it is actually dark outside helping you to conserve energy.
  • Warm welcome, every day
  • Installed in a matter of minutes
  • Place it where you want
  • Resistant to all weather conditions
  • Scare away uninvited guests
  • Automatically turn on the lights you want
Philips Hue - motion sensor - black
Motion sensor
Environment
Outdoor
Functions
Light control
Power Source
Internet of Things (IoT) Platform
Hue
Intelligent Assistant
Cortana, Google Assistant, Alexa
Wireless
Supported Host Device OS
iOS, Android
7.6 cm x 5.6 cm x 7.6 cm
Motion sensor
Environment
Outdoor
Functions
Light control
Power Source
Wireless
Android 8.0 (Oreo) or later, Apple iOS 13 or later
iOS, Android
Weatherproof, wall mountable
Hub
Required
Hub Compatibility
Philips Hue Bridge
Platform
Hue
AA type
Battery Included
Required Qty
2
Battery Lifetime
2 years
Product Material
Plastic
Warranty
IP54
7.6 cm
5.6 cm
7.6 cm
145 g
Shipping Width
17.6 cm
Shipping Depth
7.5 cm
Shipping Height
16.5 cm
Shipping Weight
305 g
-20 °C
45 °C
5 - 95% (non-condensing)
Type: Sensor
Compatible With: Alexa
Brand: Philips
