Philips Hue White Ambiance E27 Single Bulb
Quicklinx: FFS5WS00 Mfr#: 929002216901
Select:
  • E27
Add a White ambiance light bulb with warm white to cool daylight to help you relax, read, concentrate, or energize. Control instantly via Bluetooth in one room or pair with a Hue Bridge to unlock the full suite of features.
  • Control lights with your voice
    Get hands-free control of your lights and use your voice instead! Simple voice commands allow you to control multiple lights in a room or just a single lamp.
  • Set the right mood with warm to cool white light
    These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs.
  • Get the perfect light recipes for your daily activities
    Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
Philips Hue - LED light bulb - shape: A60 - E27 - 8.5 W - warm white to cool daylight - 2200-6500 K
Light Source Type
LED light bulb
Shape
A60
Socket Type
E27
Wattage
8.5 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
Warm white to cool daylight
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Dimmable
Intelligent Assistant
Siri, Cortana, Google Assistant, Alexa - indirect
Platform
Hue
Communications Technology
Bluetooth
AC 220 - 240 V
Light Source
LED light bulb
Shape
A60
Socket Type
E27
Wattage
8.5 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
8.5 kWh
Colour Temperature
2200-6500 K
Colour Rendering Index
80
Luminous Power
806 lumens
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Upgradable firmware, instant full light, Android compatible, iOS compatible, remote controlled
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Communications Type
Product-to-product
Bluetooth
Voice Controlled
Indirect
Package
Box
Warranty
2 years
Diameter
60 mm
Length
110 mm
72 g
8.8 cm x 7.5 cm x 16.5 cm / 104 g
-20 °C
45 °C
