Philips Hue Colour 9W A60 E27 Starter Kit with Bridge and Dimmer
Quicklinx: GX0LWS00 Mfr#: 929002468805
£78.42 ex VAT
£94.10 inc VAT
Marketing description is not available.
  • Be creative with colors
    Play with light and choose from 16 million colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Sync with music and films
    Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm. Download the third-party apps and discover the amazing things you can do with Philips Hue.
  • Light up your gaming
    Lift your gaming experience to the next level. Download the third party apps and discover the amazing things you can do with Philips Hue.
  • Wake up and go to sleep
    Philips Hue will help get you out of bed the way you like to, helping you start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise, and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep.
  • Create your ambiance
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of summer sun or the ice cool daylight of winter.
Philips Hue White and Color Ambiance Starter Kit - wireless lighting set - LED light bulb x 2 - shape: A60 - E27 - 9 W - 16 million colours/warm to cool white light - 2000-6500 K - white
Wireless lighting set
Light Source Type
2 x LED light bulb
Supported Light Bulbs Qty
50
White
Shape
A60
Socket Type
E27
Wattage
9 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
1100 lumens
Dimmable
Intelligent Assistant
Cortana, Google Assistant, Alexa - indirect
Platform
Apple HomeKit, Nest, Echo
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
50
Light Source
2 x LED light bulb
Shape
A60
Socket Type
E27
Wattage
9 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
9 kWh
Power Factor
0.5
Colour Temperature
2000-6500 K
Luminous Power
1100 lumens
Warm-Up Time
0.5 sec
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Upgradable firmware, ZigBee technology, instant full light, Android compatible, iOS compatible, indoor usage, voice control, app-controlled, 16 million changeable colours, controlled via Bluetooth, preset modes
Power Requirements
AC 220 - 240 V
Power Consumption Stand by
0.5 Watt
CR2450
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Compatible Application
Philips Hue App
Supported Host Device Platform
iOS, Android
Bluetooth, Zigbee
Voice Controlled
Indirect
Body Colour
White
Power adapter, network cable, Hue switch, Hue bridge
Package
Box
IP20, IEEE 802.15.4
Warranty
2 years / 30 days return
Diameter
60 mm
Length
110 mm
488 g
Dimensions & Weight Details
Switch - width: 3.5 cm x depth: 1.1 cm x height: 9.2 cm - 37 g , Wall plate - width: 1.4 cm x depth: 7 cm x height: 11.5 cm
21.9 cm x 17.6 cm x 14 cm / 950 g
-20 °C
45 °C
Type: Wireless lighting set
Compatible With: Alexa
Compatible With: Cortana
Brand: Philips
Stock Status: While stocks last
Stock Status: Clearance
