Philips Hue White Ambiance A60 B22 Twin Pack
Quicklinx: D5M4WS00 Mfr#: 929001200261
Marketing description is not available.
  • Wake up and go to sleep
    Philips Hue will help get you out of bed the way you like it, helping you to start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise and helps you to wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep.
  • Create your ambiance
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, whether it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun or the ice cool daylight of winter.
  • Light for your daily routines
    Philips Hue can help you to customize your daily routines into moments that you can enjoy. Skip your morning coffee and get ready for the day with cool, bright-white daylight that helps to energize your body and mind. Stay focused with finely tuned bright-white light. Or put your feet up and relax with a soft glow of white light for the perfect end to the day.
  • Timers for your convenience
    Philips Hue can make it seem like you're at home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times.
  • Wirelessly controllable LED
    This LED bulb is wirelessly controllable if you connect it to the Philips Hue bridge for smart control or to the Philips Hue dimmer switch.
Philips Hue White ambiance Dual Pack - LED light bulb - shape: A60 - B22 - 9.5 W - warm white to cool daylight - 2200-6500 K (pack of 2)
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Shape
A60
Socket Type
B22
Wattage
9.5 W
Wattage Equivalent
60 W
Energy Efficiency Class
A+
Colour of Illumination
Warm white to cool daylight
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Apple HomeKit, Hue
Communications Technology
Wi-Fi
AC 220 - 240 V
Packaged Quantity
Light Source
LED light bulb
Shape
A60
Socket Type
B22
Wattage
9.5 W
Wattage Equivalent
60 W
A+
Power Factor
0.5
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Instant full light, Android compatible, iOS compatible, voice control, remote controlled
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit, Hue
Wi-Fi
Voice Controlled
Indirect
Package
Hanging box
Warranty
2 years
Diameter
62 mm
Length
110 mm
136 g
140 mm x 75 mm x 165 mm / 350 g
-10 °C
45 °C
