Directing its light in triangular light effects both up and down, the Resonate lamp allows you to illuminate your porches and patios with elegant, colorful light.
Warm to cool white light
Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year. -
Decorate for the holidays with light
Holiday cheer starts here - with smart light! Use your Philips Hue lights to transform your home into a festive experience: bright reds and greens for Christmas, subtle pastels for spring or even an eerie purple glow to create the most haunted house on the street at Halloween. -
Control it your way
Connect your Philips Hue lights with the Bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add the indoor switches to your system to change your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. -
Weather-proof (IP44)
This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use.
- Philips Hue White and Color Ambiance Resonate - wall lamp - LED x 2 - 8 W - 2000-6500 K - stainless steel
- Product Type
- Wall lamp
- Light Source Type
- 2 x LED
- Dimmer
- Stainless steel
- Wattage
- 8 W
- Wattage Equivalent
- 49 W
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 1200 lumens
- Intelligent Assistant
- Siri, Google Assistant, Alexa - indirect
- Platform
- Hue
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- Wall lamp
- Dimmer
- Weatherproof, outdoor usage, splashproof, protection class I, app-controlled
Light Source
- 2 x LED
- Built-in LED Lamp
- Wattage
- 8 W
- 49 W
- 2000-6500 K
- Luminous Power
- 1200 lumens
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Compatible Application
- Philips Hue App
- Voice Controlled
- Indirect
- Product Material
- Stainless steel
- Body Colour
- Stainless steel
- IP44
- Warranty
- 2 years
- 93 mm
- 120 mm
- 180 mm
- 781 g
- Shipping Dimensions (WxDxH) / Weight
- 15.5 cm x 12.5 cm x 22 cm / 950 g
