Philips Hue White Ambiance 3 Bulb E27 + Switch Starter Kit
Quicklinx: D5M7WS00 Mfr#: 929001200161
Always create the perfect ambience with this Philips Hue smart light starter kit. It includes three bulbs that you can turn on from your phone or tablet, so you can arrive to a bright, cosy home at the end of the day. As they’re white bulbs, you can be confident that they’ll always produce clear light. Each bulb has a simple screw fitting and a 25,000 hour lifespan too. It’s easy to set a timer as well, so when you’re sunning yourself on holiday, it’ll still look like you’re at home. The bulbs even work with the Apple HomeKit and Amazon Echo smart speakers, letting you control the lighting with simple voice commands, so you’ll never need to lift a finger.
The kit also includes the Philips Bridge hub, needed for the lights to work, and a wireless dimmer switch. You’ll also need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
Key Features
  • Smart light bulb – control from your phone or tablet
  • White bulb - provides clear lighting for your home
  • Screw fitting with 25,000 hour lifespan
  • Schedule a timer to turn lights on automatically
  • Works with Google Home, Amazon Alexa and Apple HomeKi
  • Control it your way
    Control your lights from your smartphone or tablet, or add switches to your system to activate your lights.
  • Create your ambiance with warm white to cool daylight
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun, or the ice cool daylight of winter.
  • Energize yourself
    Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind. Perfect for those moments when your batteries are running low and you need a kickstart.
Philips Hue White ambiance Starter Kit - wireless lighting set - LED light bulb x 3 - shape: A60 - E27 - 9.5 W - total: 28.5 W - cool white/warm white light - 2200-6500 K
Wireless lighting set
Light Source Type
3 x LED light bulb
Supported Light Bulbs Qty
50
Total Wattage
28.5 W
Shape
A60
Socket Type
E27
Wattage
9.5 W
Energy Efficiency Class
A+
Colour of Illumination
Cool white/warm white light
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Intelligent Assistant
Alexa - indirect
Platform
Hue
Communications Technology
Zigbee
AC 100 - 240 V
Frequency Required
50 - 60 Hz
50
Total Wattage
28.5 W
iOS compatible, upgradable firmware
Light Source
3 x LED light bulb
Shape
A60
Socket Type
E27
Wattage
9.5 W
A+
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Lifetime
25000 hours
Upgradable firmware, instant full light
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
1 x CR2450
Internet of Things (IoT)
Hub
Included
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Communications Type
Product-to-product
Zigbee
Alexa
Voice Controlled
Indirect
Wall bracket, power adapter, wireless bridge, network cable, dimmer switch, battery
Warranty
2 years
Dimensions & Weight Details
Light bulb height: 110 mm x diameter: 62 mm , Wireless bridge - width: 88 mm x depth: 88 mm x height: 26 mm , Dimmer switch - width: 35 mm x depth: 11 mm x height: 117 mm , Wall bracket - width: 70 mm x depth: 14 mm x height: 114 mm - 67 g
