Decorate with ambient smart lights
Transform the atmosphere of your home with just the touch of a button. Use over 16 million colors and 50,000 shades of cool to warm white light to create special moments, set the mood for a party, or simply wind down for the evening. -
Create your ambiance with warm white to cool daylight
Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, whether it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun or the ice-cool daylight of winter. -
Amp your entertainment with smart lighting
Immerse yourself in your movie, game, or music with the magic of light. With millions of colors from which to choose and countless lighting options, you can turn any living room into a private cinema - all you need to bring is the popcorn! -
Connect 3 Hue Play light bars with 1 plug
Hue Play won't add to a jumble of wires behind your TV or hog too many outlets. You can connect three Hue Play smart light bars to the same power supply unit, leaving you more than enough room for all your other devices. -
Control it your way
Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms and more for the full Philips Hue experience.
- Philips Hue White and Color Ambiance Play - light bar - LED - warm white to cool daylight - 2000-6500 K - black (pack of 2)
- Product Type
- Light bar
- Recommended For
- Living room, bedroom
- Light Source Type
- LED
- Packaged Quantity
- 2 (specifications are for single item)
- Style
- Expressive
- Dimmer
- Cable Length
- 2 m
- Black
- Wattage Equivalent
- 42 W
- Colour of Illumination
- Warm white to cool daylight
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 500 lumens
- Intelligent Assistant
- Google Assistant, Alexa
- Platform
- Apple HomeKit, Hue
- Frequency Required
- 50 - 60 Hz
- Packaged Quantity
- Product Type
- Light bar
- Recommended For
- Style
- Expressive
- Dimmer
- Cable Length
- 2 m
- Wall mountable, protection class III, 16 million changeable colours, app-controlled, EyeComfort, power on/off timer, voice control, TV-mountable, gaming light
Light Source
- LED
- Built-in LED Lamp
- 42 W
- 2000-6500 K
- Luminous Power
- 500 lumens
- Lifetime
- 25000 hours
Power Requirements
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Compatible Application
- Philips Hue App
- Product Material
- Synthetics
- Body Colour
- Black
- Included Accessories
- Hue bridge, power supply
- IP20
- Warranty
- 2 years
- 25.3 cm
- 4.4 cm
- 3.6 cm
- 710 g
