Philips Hue Impress Wall Lantern - Low Volt System / Extendable
Quicklinx: GNW1WS00 Mfr#: 915005842101
Make an impression with the Impress low-voltage wall light. This modern glass-enclosed fixture needs only a wall socket to give you dusk-till-dawn light in millions of colors.
Easy to install and extend
Brighten up dark paths, create highlights in your landscaping or create a unique ambience on the patio. You can do it yourself, using Hue spots or bollards. The products are based on low voltage, safe to use and easy to install. No more complexity to get lighting outdoors: start to create and extend to suit your needs.
Weather-proof (IP44)
This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use.
Requires a Philips Hue bridge
Connect your Philips Hue lights with the Bridge to control your lights from your smart phone or tablet via the Philips Hue app. Or control your Philips Hue lights with the Philips Hue dimmer indoor switch for on/off and dimming functionalities.
  • Weather-proof (IP44)
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments for great performance. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use.
  • Easy to install and extend
    Brighten up dark paths, create highlights in your landscaping or create a unique ambience on the patio. You can do it yourself, using Hue spots or bollards. The products are based on low voltage, and are safe to use and easy to install. No more complexity to get lighting outdoors: start to create and extend to suit your needs.
  • High-quality aluminum and tempered glass
    Philips uses high-quality aluminum and tempered glass to ensure advanced performance in outdoor conditions. As well as smart use of materials to optimize radio frequency.
  • Control it your way
    Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add the indoor switches to your system to change your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple Homekit and the Google Assistant to allow you to control your lights with your voice.
  • Unwind with warm to cool white light
    Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
  • Decorate for the holidays with light
    Holiday cheer starts here - with smart light! Use your Philips Hue lights to transform your home into a festive experience.
Philips Hue White and Color Ambiance Impress - wall lamp - LED - 8 W - 16 million colours - 2000-6500 K - black
Wall lamp
Light Source Type
LED
Dimmer
Wattage
8 W
Wattage Equivalent
49 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1200 lumens
Intelligent Assistant
Google Assistant, Alexa
Platform
Hue
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Light Source Voltage
24 V
Wall lamp
Dimmer
Waterproof
Weatherproof, outdoor usage, splashproof, protection class III, app-controlled
Light Source
LED
Built-in LED Lamp
Wattage
8 W
Wattage Equivalent
49 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1200 lumens
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
24 V
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Compatible Application
Philips Hue App
Product Material
Aluminium, tempered glass
Body Colour
IP44
Warranty
2 years
120 mm
141 mm
240 mm
1.99 kg
140 mm x 260 mm x 334 mm / 2.35 kg
