Philips Hue Go
Philips Hue Go
Quicklinx: DL5TWS00 Mfr#: 915004576901
  • On-product control
    Control Philips Hue Go even without your smart device at hand. Activate light settings directly by pressing the button on the product. Choose from 7 different light effects: functional warm white light, cool energizing daylight and 5 natural dynamic light effects that match your special moments. Or cycle through the color choices by quickly tapping and then holding the button until the desired color comes up. The fun really starts when you connect Philips Hue Go with the Bridge. Control Philips Hue Go from your smart device and discover the endless possibilities.
  • Be creative with colors
    Play with light and choose from 16 million colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Sync with music and films
    Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm.
Philips Hue Go - desk lamp - LED - 6 W - 16 million colours - white
Desk lamp
Light Source Type
LED
Switch Location
Body
Dimmer
White
Wattage
6 W
Colour of Illumination
16 million colours
Luminous Power
300 lumens
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Desk lamp
Switch Location
Body
Dimmer
Android compatible, iOS compatible, ZigBee Light Link, upgradable firmware, diffused light effect
Light Source
LED
Built-in LED Lamp
Wattage
6 W
16 million colours
Luminous Power
300 lumens
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Product Material
Synthetics
Body Colour
White
IP20
Warranty
2 years
15 cm
15 cm
7.9 cm
900 g
