Get even closer to your audience than ever before. Fast, precise and extremely durable, its high performance is matched by excellent reliability and functionality
Full HD LED technology
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen. -
AMVA display technology
Philips AMVA LED display uses an advanced multi-domain vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard applications are handled with ease, it is especially suitable for graphical demanding applications. It's optimized pixel management technology gives you 178/178 degree extra wide viewing angle, resulting in crisp images even in portrait mode. -
Optical multi-touch
A brand new level of interactivity is now available thanks to the integrated optical touch technology. The sensors on the edge of the screen give you perfect clarity whilst at the same time offering multi-touch interaction, opening up all kinds of possibilities for interactive applications. -
USB Plug-and-Play
Simply connect the display via USB to your mediaplayer for automatic touch recognition. The USB connector is HID compliant, providing true Plug-and-Play operation. -
OPS Slot
Developed for the digital signage market, the Open Pluggable Specification (OPS) slot is designed to make changing or upgrading your media player mere child's play. Simply plug your media player in to the display - and you're ready. No matter whether you have an entry level, mid-range or high-end media player, OPS is fully compatible bringing you a lower TCO over the longer term. -
Smart Insert
Professional PC's are part of most public signage installations. Quite often they increase the overall depth to the display and cause a lot of cable clutter. So this display is with smart insert in the back cover which is ideal for the integration of a professional small form factor PC. On top of that, the cable management system offers a great solution to keep your cables neat and professional looking. -
Smart Control
Control and manage all of the signage displays on your network with this powerful software tool which allows you to change the settings of your display centrally. Smart Control allows you to set the video input, modify the color settings, set the display's ID when creating video walls and even diagnose each display's status, giving you all the power you need to manage your displays from one central location. -
Freeze operation
Activate the freeze option during your presentation, to switch the content on your computer without having your audience to see it. Simply deactivate the freeze option when ready to play the live video source again.
- Philips Signage Solutions BDL6526QT 65" Class (64.5" viewable) LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 65"
- Diagonal Size
- 64.5"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Input Video Formats
- 1080/60i, 480/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 1 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- Technology
- AMVA
- LCD Backlight Technology
- WLED backlight - edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- Pixel Shift
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, batteries, carrying handle
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 250 Watt
- Power Consumption (On mode)
- 130 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 190 kWh
- Dimensions (WxDxH) - without stand
- 155.4 cm x 11 cm x 92.9 cm
- 65.6 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A
- 250 Watt
- 130 W
- 190 kWh
- Diagonal Class
- 65"
- Diagonal Size
- 64.5"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- Modes
- Portrait mode
- Pixel Shift
- Dimensions
- Without stand
- 155.4 cm
- 11 cm
- 92.9 cm
- 65.6 kg
Display
- LCD Display Technology
- AMVA
- Resolution
- 1920 x 1080
- 16:9
- Coating
- Anti-glare
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 360 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.74 x 0.74mm
- Pull-Down Compensation
- 3:2, 2:2
- Touchpoints Qty
- 6
- Response Time
- 8 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish
- Comb Filter
- 3D digital
- Dynamic Contrast, 3D MA deinterlacing, Multitouch, Smart Insert, Optical Touch technology, Open Pluggable Specification slot, Smart Control, Motion Compensation
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800, 1600 x 900
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connector Type
- HDMI , VGA input , S-Video input , Audio line-in , VGA output , DVI-D input , Component video input , Composite video input , Composite video output , Audio line-in , Audio line-out , Speakers output , LAN , Serial , USB
- Batteries, carrying handle
- Cables Included
- VGA cable , Serial cable , USB cable
- FCC Class B certified, UL, C-Tick, cUL, SASO, CB, CCC, RoHS, Lead-Free, EMF, KUCAS, EPA, EAC
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- Smart power
- Limited warranty - 3 years
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 155.4 cm x 11 cm x 92.9 cm x 65.6 kg
- 5 °C
- 40 °C
- 20 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
