Philips 55BDL3050Q 55" 3840x2160 8ms VGA DVI HDMI LED Large Format Display
Quicklinx: FFBDWS00 Mfr#: 55BDL3050Q/00
Deliver startlingly clear images in a more eco-friendly way with the Q-Line display. High on performance and reliability, yet low on power consumption, it is ideal for projects where no compromise is accepted.
  • 4K Ultra HD resolution
    See your signage solutions like never before thanks the higher resolution. 3840 x 2160 pixels provide an image so refined, so lifelike, it's a window to another world.
  • CMND & Control
    With CMND & Control, easily manage multiple displays in a central location. With real-time display monitoring, setting and software updates from a remote location, and the ability to customize and configure multiple displays at once, such as video wall or menu board displays, controlling your suite of displays has never been easier.
  • CMND
    A robust display management platform, CMND puts the power back into your hands. Update and manage content with CMND & Create or control your settings with CMND & Control. It's all possible with CMND.
  • CMND & Create
    Design and create compelling content with CMND & Create, a powerful authoring tool. With a drag and drop interface, preloaded templates, and integrated widgets, you'll be able to amaze your customers with compelling content. Available in portrait and landscape mode.
  • SmartBrowser
    Connect and control your content via the cloud with the integrated HTML5 browser. Design your signage content online and connect it with a display or with your complete network. Simply plug in an RJ-45 Internet cable for network connection, connect the display with the dedicated URL-address and you are ready to play your cloud-based content.
  • SmartPlayer
    Turn your USB into a true cost-effective digital signage device. Simply save your content (video, audio, pictures) on your USB and plug into your display. Create your playlist and schedule your content via the on screen menu, and enjoy your own created playlists anytime, anywhere.
  • SmartPower
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption, which saves substantially on energy costs.
Philips 55BDL3050Q Q-Line - 55" Class (54.6" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/337838
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - digital signage
Platform
Android
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
480/60p, 720/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p, 480/30p, 1080/30i, 2160/50p, 2160/60p, 1080/25i, 480/30i, 576/25i, 576/25p
Max Number of Screens
150
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15)
AMVA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
HTML5 support, CMND management
Picture Enhancements
Colour temperature adjustment, Noise Reduction, dynamic contrast enhancement, Pixel Shift, Colour Enhancement, 3D Digital Comb Filter
Speaker System
2 speakers
Storage Drive Capacity
8 GB
Storage Capacity
8 GB
Supported Memory Cards
microSD
USB
Remote control, batteries
Voltage
Energy Class
Class G
Power Consumption (On mode)
125 W
Power Consumption Stand by
0.5 watt
Energy Consumption per Year
212 kWh
123.92 cm x 6.17 cm x 71.16 cm
15.96 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class G
125 W
125 kWh/1000h
212 kWh
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Series
Q-Line
Platform
Android
Operating System
Android OS 5.1
Video Processor
Quad-Core
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
Modes
Landscape mode
Dimensions
Without stand
123.92 cm
6.17 cm
71.16 cm
15.96 kg
Display
LCD Display Technology
AMVA
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Multilingual
Backlight Life
50,000 hour(s)
Commercial Features
3D MA deinterlacing, security lock slot (cable lock sold separately)
Video Wall
150
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm, 400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 1920 x 1080, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, ASF, AVI, MKV, MOV, VOB, FLV, TS, DAT, TRP, WebM
Supported Audio Formats
MP3, WMA, AAC, M4A
Supported Pictures Formats
BMP, JPG, PNG, JPEG
microSD
USB Port
Configuration
8 GB
8 GB
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 watt
Speakers
2 x speaker - 10 watt
Network & Internet Multimedia
LAN
Connector Type
DVI-D input , VGA input , 2 x HDMI , Audio line-in , Audio line-out , Serial input , Serial output , Infrared input , Infrared output , LAN , Audio line-in , USB 2.0
Batteries
Serial cable , IR extender cable - 1.8 m
FCC Class B certified, UL, BSMI, cUL, CB, CCC, PSB, EMF, EAC
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Input Voltage
0.5 watt
Power Consumption (Off Mode)
0.5 watt
Smart power
Limited warranty - 3 years
20 - 80%
