Philips 65BDL4150D 65" 3840x2160 8ms VGA DVI HDMI DisplayPort LED Large Format Display
Quicklinx: FMX4WS00 Mfr#: 65BDL4150D/00
TV Tuner Presence: No
Video Interface: HDMI
£1,645.60 ex VAT
£1,974.72 inc VAT
Impress with a large diameter display. The Philips D-Line is a high-performance powerhouse for corporate, educational and similar environments that need to go bigger.
  • Ultra HD resolution
    See your signage solutions like never before thanks to four times the resolution of a conventional Full HD display. More pixels provide and image so refined, so lifelike, it's a window to the world.
  • Smart power
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption, which saves substantially on energy costs.
  • Content protection
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, D-Line provides content protection with an incredible technology that plays back-up content on screen in the event of a media player failure.
Philips 65BDL4150D D-Line - 65" Class (64.5" viewable) LED-backlit LCD display - 4K
LED-backlit LCD flat panel display
Diagonal Class
65"
Diagonal Size
64.5"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Max Number Of Screens
150
Video Interface
HDMI
HDMI Ports Qty
4 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
CMND management, Open Pluggable Standard (OPS) support
Picture Enhancements
Pixel Shift, 3D Digital Comb Filter
Speaker System
2 speakers
Storage Drive Capacity
32 GB
Storage Capacity
32 GB
USB
3 ports
Remote control, batteries
Voltage
Energy Class
Class G
267 Watt
Power Consumption (On mode)
181 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
262 kWh
145.78 cm x 6.69 cm x 83.56 cm
36.5 kg
3-year warranty
Energy Class
Class G
267 Watt
181 W
181 kWh/1000h
262 kWh
Diagonal Class
65"
Diagonal Size
64.5"
Commercial Use
Series
D-Line
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
Modes
Portrait mode, landscape mode
150
Dimensions
Without stand
145.78 cm
6.69 cm
83.56 cm
36.5 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1100:1
Dynamic Contrast Ratio
500000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Multilingual
Backlight Life
50,000 hour(s)
Commercial Features
Operation Hours / Days
24 / 7
3D MA deinterlacing, Smart Insert, picture in picture (no tuner)
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
VESA Compatibility
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1440 x 1050, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 1280 x 720, 640 x 350, 720 x 400, 848 x 480, 1152 x 900, 1360 x 768, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1400 x 1050, 1600 x 900, 3840 x 2160, 4096 x 2160, 960 x 720
Media Player
Supported Video Formats
MPEG-4, WMV, ASF, AVI, MKV, VOB, FLV, TS, DAT, WebM, MPEG
Supported Audio Formats
MP3, WMA, AAC, M4A
Supported Pictures Formats
BMP, JPG, PNG, JPEG
USB Port
USB Ports Qty
3
Configuration
32 GB
32 GB
Operating System
Android OS 7.1.2
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DisplayPort input , 4 x HDMI input , DVI-D input , VGA input , DisplayPort output , SPDIF output , Audio line-in , Audio line-out , USB , USB 2.0 , USB 3.0 , Remote control , Serial input , Serial output , Infrared input , Infrared output
Batteries
Serial cable , VGA cable
FCC Class B certified, CB
Power supply
Input Voltage
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Smart power
Limited warranty - 3 years
20 - 80%
Brand: Philips
Price Range Ex VAT: £1500+
