Philips 43HFL3011T 43" EasySuite LED Commercial TV
Quicklinx: FF9PWS00 Mfr#: 43HFL3011T/12
  • 1080p
  • DVB-T
Send the right message to your guests with high picture quality and the ability to show branded, interactive hotel pages.
  • Full hotel, healthcare and prison modes
    All required features for professional use in environments where more is required than in a living room. From volume and menu locking to more rigorous material testing, energy saving, anti-theft remote controls and dedicated healthcare and prison features to allow for niche market applications.
  • On-screen clock display for optimal guest convenience
    With the on-screen clock display, guests can easily access the current time. At a push of a button the clock is being displayed on the TV screen combining enhanced visibility and lower power consumption.
  • Optimized for the healthcare sector
    Nurse-call system compatibility makes Philips healthcare TVs a highly integrated tool that provides not only entertainment options for the user/patient but also gives convenient access to help in medical emergencies.
  • Schedule what you want, when you want
    Show what you want, when you want with the built-in scheduler. Program different schedules to show any type of content you want. Repeat every day, or set it for particular days such as the weekend, the choice is yours.
Philips 43HFL3011T EasySuite - 43" LED-backlit LCD TV - Full HD - for hotel / hospitality
LED-backlit LCD TV
Diagonal Class
43"
Commercial Use
Yes - hotel / hospitality
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60p
Frame Rate & Enhancement Technology
200 Hz Perfect Motion Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Analogue TV Tuner
PAL
Commercial Features
Screen welcome message, prison mode, VSecure, healthcare mode, mychoice, Serial Xpress Protocol, Bathroom Speaker Output, Double isolation Class II, Independent main speaker mute, HTML5 support, SmartInfo, Nurse call system compatible, Multi remote control, CMND management, Wake Up Alarm
Settings Cloning Capability
Picture Enhancements
Pixel Plus HD
Speaker System
2 speakers
Sound Effects
Incredible Surround
USB
2 ports
Philips 22AV1503A/12 remote control, 2 AAA batteries
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A+
Power Consumption (On mode)
40 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
58 kWh
97.1 cm x 6.7 cm x 56.4 cm
9.2 kg
LED-backlit LCD TV
Energy Class
Class A+
40 W
58 kWh
Diagonal Class
43"
Commercial Use
Series
EasySuite
TV Tuner Presence
Video Interface
HDMI Ports Qty
3 ports
Modes
Eco mode, hotel mode
Pixel Plus HD
Design
Flame retardant cabinet
Protection
Theft protection
Dimensions
Without stand
97.1 cm
6.7 cm
56.4 cm
9.2 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Brightness
280 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Commercial Features
Slide Show Function, One touch Play, security lock slot (cable lock sold separately), Scheduler
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Analogue TV Tuner
PAL
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
MHEG
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM
Input Video Formats
1080/60p
Teletext
Electronic Programme Guide
Digital EPG, Now & Next
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV, AVI, MKV, TS, AVC, H.264, VC-1, HEVC, MPG
Supported Audio Formats
MP3, WMA, WAV, AAC
Supported Pictures Formats
BMP, JPG, GIF, PNG
USB Port
USB Ports Qty
2
Remote Control
Remote control
Remote Control Model
Joystick, low battery alert, battery anti-theft protection
Audio System
Digital Audio Format
Dolby Digital output
Surround Mode
Sound Effects
Incredible Surround
Speaker System
2 speakers
Output Power / Total
16 Watt
Down-firing Speaker, Auto Volume Leveller (AVL), Audio Return Channel (ARC), System Audio Control
Speakers
2 x speaker - 8 Watt
Network & Internet Multimedia
Functionality
WEB browsing
Supported Consumer Electronics Control (CEC)
EasyLink
Connector Type
2 x HDMI - rear , USB 2.0 - rear , Digital audio output (optical) - rear , Audio line-in - rear , Composite video / component video input - rear , Audio line-in - rear , Remote control - rear , Speakers output - rear , HDMI - side , USB 3.0 - side , Headphone output
2 AAA batteries
HDCP 2.2
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.3 Watt
System standby
Dimensions & Weight Details
Panel without stand - 97.1 cm x 6.7 cm x 56.4 cm x 9.2 kg , Panel with stand - 97.1 cm x 21.2 cm x 62.76 cm x 11.2 kg
