Philips BDL4988XC 49" Video Wall Display
Quicklinx: FFC9WS00 Mfr#: BDL4988XC/00
  • 1080p
Impress your audience with the most impactful video wall. With ultra narrow bezel and stunning picture quality, you are sure to create the memorable visual experience.
  • IPS display technology
    Philips IPS displays uses an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in portrait mode. IPS displays gives you remarkably crisp images with vivid colors, especially suitable for professional video wall and menu board applications which demand color accuracy and consistent brightness at all times.
  • Ultra Narrow Bezel
    The next generation of video wall displays is designed with narrow bezels and advanced alignment solutions. Fully exploit your impactful signage content with ultra narrow bezel displays, and make sure your message does not get lost by thick bezels. With the ultra narrow bezels you can create seamless video wall configurations of virtually any size.
  • FailOver
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides content protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and you're ready for instant protection.
  • SmartPower
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption, which saves substantially on energy costs.
  • SmartPlayer
    Turn your USB into a true cost-effective digital signage device. Simply save your content (video, audio, pictures) on your USB and plug into your display. Create your playlist and schedule your content via the on screen menu, and enjoy your own created playlists anytime, anywhere.
Philips Signage Solutions BDL4988XC 49" Class (48.5" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
49"
Diagonal Size
48.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Max Number of Screens
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Dynamic contrast enhancement, Pixel Shift, Advanced Colour Calibration
Speaker System
2 speakers
Remote control, batteries, edge alignment pins, edge alignment plates
Energy Class
Class A
110 Watt
Power Consumption (On mode)
76 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
111 kWh
107.76 cm x 10.38 cm x 60.78 cm
21.6 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class A
110 Watt
76 W
111 kWh
Diagonal Class
49"
Diagonal Size
48.5"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Ultra Narrow Bezel Concept
Dimensions
Without stand
107.76 cm
10.38 cm
60.78 cm
21.6 kg
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Direct-lit LED
Image Contrast Ratio
1300:1
Dynamic Contrast Ratio
500000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
60,000 hour(s)
Certified for 24/7 Continuous Operation, 3D MA deinterlacing, Open Pluggable Specification slot
Video Wall
100
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800, 3840 x 2160
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Connector Type
Component video input , Composite video input , DVI-D input , 2 x HDMI , DisplayPort input , DisplayPort output , DVI-I , Audio line-in , Audio line-in , Remote control , LAN , Serial , Speakers output , VGA input , Audio line-out
Batteries, edge alignment pins, edge alignment plates
DVI cable , Serial cable
FCC Class B certified, UL, GOST, cUL, CB
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
