Command attention with a Philips X-Line Professional Videowall Display. Crisp contrast and narrow bezels enable clear, distraction-free imaging. Whether you're running an airport or hosting a conference.
Tiling mode
Connect two or more Philips professional displays to create a tiled videowall - without the need for external devices. A single player takes care of content, whether you have four screens or 40. 4K content is fully supported, and if you're showing that content on four screens you get the best possible dot-by-dot resolution. -
CMND & Control
Run your display network over a local (LAN) connection. CMND & Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100. -
OPS slot
The OPS slot contains all the connections you need to run your slot-in solution, including a power supply.
- Philips Signage Solutions Video Wall Display 55BDL3005X X-Line Professional Videowall - 55" Class (54.6" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- Motion Compensation, dynamic contrast enhancement, Pixel Shift, 3D Digital Comb Filter, Low Bright
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, batteries, thumb screw, edge alignment pins, edge alignment plates
- Voltage
- AC 120/230 V
- Power Consumption (On mode)
- 110 W
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - panel
- 121.34 cm x 10.765 cm x 68.42 cm
- 26.5 kg
- 3-year warranty
- Product Type
- 110 W
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Series
- X-Line Professional Videowall
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Portrait mode, landscape mode, Tiling Mode (10 x 10)
- Dimensions
- Panel
- 121.34 cm
- 10.765 cm
- 68.42 cm
- 26.5 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Image Contrast Ratio
- 1400:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
- Backlight Life
- 60,000 hour(s)
- 3D MA deinterlacing, 3:2 pull down compensation, 2:2 pull down compensation
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
- VESA Compatibility
Video Features
- Supported Computer Resolutions
- 1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800, 3840 x 2160
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
- Connector Type
- Component video input , Composite video input , DVI-D input , 2 x HDMI input , VGA input , DisplayPort input , DisplayPort output , DVI-I output , Audio line-in , Audio line-out , Extension speaker output , IR emitter , LAN , RS-232C
- Batteries, thumb screw, edge alignment pins, edge alignment plates
- Cables Included
- IR cable , IR sensor cable - 1.8 m , RS-232 daisy chain cable , RS-232 cable , DVI cable
- FCC Class B certified, UL, GOST, cUL, CB
- Power Device
- Power supply
- Input Voltage
- AC 120/230 V
- 0.5 Watt
- Smart power
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
