Philips Signage Solutions 10BDL4151T 10.1" LED Display
Quicklinx: FF92WS00 Mfr#: 10BDL4151T/00
Run your display network over a local (LAN) connection. CMND and Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100.
The built-in camera and speakers make this small touchscreen a truly versatile smart solution. Use it for retail audience measurement, footfall analytics, and more. Harness the power of Android AI apps to show targeted content. Or simply use your display for video conferencing.
Place your Philips Professional Display almost anywhere. PoE+ allows power and data to be delivered to your display over a single Ethernet cable. You won't need a power socket, but a power adapter is also supplied should you wish to plug in.
  • CMND and control, operate, monitor, maintain
  • Built-in camera and speakers
  • Easy installation with PoE+ technology
  • Internal memory, upload content for instant play
    Save and play content without the need for a permanent external player. Your Philips professional display has an internal memory, which allows you to upload media into the display for instant playback. The internal memory also functions as a cache for online streaming.
  • CMND and create, develop and launch your own content
    Take control of your content with CMND and Create. A drag-and-drop interface makes it simple to publish your own content, whether it's a daily specials board or branded corporate information. Preloaded templates and integrated widgets ensure that your stills, text and video will be up and running in no time.
Philips Signage Solutions 10BDL4151T 10.1" LED-backlit LCD display - HD - for digital signage / interactive communication
LED-backlit LCD flat panel display with touchscreen (multi touch) / camera
Diagonal Class
10.1"
Commercial Use
Yes - interactive digital signage
Platform
Android
Resolution
1280 x 800
Display Format
720p
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:10
TV Tuner
No tuner
Speaker System
2 speakers
Storage Drive Capacity
8 GB
Storage Capacity
8 GB
Supported Memory Cards
microSD
USB
Silicone foot
Power Consumption Stand by
0.5 Watt
26.1 cm x 2.9 cm x 16.72 cm
710 g
3-year warranty
Diagonal Class
10.1"
Commercial Use
Combined With
Touchscreen (multi touch) / camera
Platform
Android
Operating System
Android OS 7.1
TV Tuner
No tuner
TV Tuner Presence
No
Modes
Portrait mode, landscape mode
Dimensions
Without stand
26.1 cm
2.9 cm
16.72 cm
710 g
Display
Resolution
1280 x 800
Display Format
720p
Image Aspect Ratio
16:10
LED backlight
Image Contrast Ratio
500:1
Brightness
300 cd/m²
Viewing Angle
160 degrees
Viewing Angle (Vertical)
160 degrees
Touchpoints Qty
5
Response Time
30 ms
Display Menu Language
Multilingual
Backlight Life
50,000 hour(s)
Operation Hours / Days
24 / 7
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
75 x 75 mm
VESA Compatibility
Media Player
Supported Video Formats
MPEG-4, AVI, MKV, MOV, VOB, FLV, TS, DAT, WebM, MPG, 3GP
Supported Audio Formats
MP3, WMA, AAC, M4A, MP2
Supported Pictures Formats
BMP, JPG, GIF, PNG, JPEG
microSD
USB Port
Configuration
8 GB
8 GB
Audio System
Speaker System
2 speakers
Output Power / Total
4 Watt
Speakers
2 x speaker - 2 Watt
Connector Type
HDMI output , USB , Audio line-out , Remote control
Silicone foot
USB cable , HDMI cable
FCC Class A certified, UL, CB, RoHS
Power adapter
0.5 Watt
Smart power, PoE support
Limited warranty - 3 years
5 °C
20 - 80%
