Peerless-AV’s PJF3 Projector Mount is loaded with an array of features to enhance your viewing experience. Using a sleek column design, the PJF3 allows versatile mounting of the projector. Its toolless height, image adjustment and quick-release mechanism provide easy setup and projector maintenance.
- Peerless-AV SmartMount Projector Mount PJF3-EXB-W mounting kit - Tilt & Swivel - for projector - white powder coat
- Product Type
- Mounting kit (Tilt & Swivel)
- Mounting Components
- Extension column, ceiling plate, mounting adapter
- 44.8 cm x 44.8 cm
- Adjustable Height
- 45.7-68.6 cm
- Tilt
- -20° to 20°
- Rotation
- 360°
- Adjustments
- Roll, height
- 2.27 kg
- Recommended Use
- Projector
- Max Mounting Pattern Size
- 448 x 448 mm
- Max Load Weight
- 24.9 kg
- White powder coat
- 5-year warranty
- 44.8 cm
- 44.8 cm
- Adjustable Height
- 45.7-68.6 cm
- 2.27 kg
- White powder coat
AV Furniture
- Mounting kit
- Design
- Tilt & Swivel
- Recommended Use
- Projector
- 448 x 448 mm
- Cable Management
- Integrated cable management
- Tilt
- -20° to 20°
- Rotation
- 360°
- Adjustments
- Roll, height
- Max Load Weight
- 24.9 kg
- Limited warranty - 5 years
