Peerless-AV's Modular mount series fulfills multiple requirements with a limited number of components. The universality of the components allows you to configure your own perfect custom flat-panel display or projector mounting solution for any application. The Modular mount series was developed with the professional AV installer in mind with a 2" (50 mm) diameter support pole that can be easily cut to length on the job site making it ideal for new projects as well as for upgrading existing installations.
Versatile placement options
Designed for both ceiling and floor mounting, the Peerless Modular Series MOD-ACF2 offers flexible installation options to meet diverse needs. Whether it's a flat panel or projector, this mounting component ensures a secure and optimal placement. -
Robust design
With a maximum load weight of 192 kg, this mounting component is built to support large displays ranging from 46"-90". Its robust construction, complemented by security screws, provides a stable and secure setup for your valuable equipment. -
Seamless integration
The MOD-ACF2 features a sleek plate cover and two pole holes, allowing for a clean and unobtrusive installation. This design not only enhances the aesthetic appeal of your space but also ensures easy access for maintenance and adjustments.
- Peerless Modular Series MOD-ACF2 mounting component - for flat panel / projector - black powder coat
- Product Type
- Mounting component - ceiling mountable, in-floor mounted
- Mounting Components
- Plate cover
- 20.4 cm x 20.4 cm x 3.1 cm
- 450 g
- Recommended Use
- Flat panel / projector
- Recommended Display Size
- 46"-90"
- Max Load Weight
- 192 kg
- Black powder coat
- Limited lifetime warranty
- 20.4 cm
- 20.4 cm
- 3.1 cm
- 450 g
- Black powder coat
AV Furniture
- Plate cover
- Recommended Use
- Placing / Mounting
- Ceiling mountable, in-floor mounted
- 46"-90"
- Max Load Weight
- 192 kg
- Security screws, 2 x pole holes
- Limited warranty - 5 years
