Peerless-AV PRSS Projector Mount Ceiling Kit
Quicklinx: 9Z1KWS00 Mfr#: MOD-PRSSKIT150-CPF
The Peerless-AV Modular Mount Line includes a small and easily manageable number of sku's, yet provides a full range of options that can fulfill a vast majority of end-user requirements. Universal components make it quick and easy to design and configure the perfect custom projector mounting solution, ideal for any application. Designed around a 2" (50mm) diameter extension pole, the line is ideal for new projects as well as upgrading existing installations. The MOD-PRSSKIT Ceiling Mount Kits include all of the components required to mount a projector from the ceiling.
Peerless Modular Series MOD-PRSSKIT mounting kit - for projector - black chrome
Mounting kit
Mounting Components
Ceiling plate, extension pole, universal adaptor
Pan
360°
Adjustments
Roll, tilt
Recommended Use
Projector
Max Mounting Pattern Size
448 x 448 mm
Max Load Weight
22 kg
Black chrome
5-year warranty
Black chrome
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Projector
448 x 448 mm
Cable Management
Integrated cable management
Pan
360°
Adjustments
Roll, tilt
Max Load Weight
22 kg
Quick release, swivel adjustment
Dimensions & Weight Details
Dimensions
Column - height: 1.5 m
Limited warranty - 5 years
