Panasonic TH-49LF80W 49" Full HD LCD Large Format Display
Quicklinx: CBYFWS00 Mfr#: TH-49LF80W
  • 1080p
This stylish design blends in with surrounding spaces and fills the screen with images. The 6.3 mm (0.25") bezel width of the LF80 series is less than half the 16 mm (0.7") bezel width of the LF60 Series. And the slim design makes the depth only 57 mm (2.3"). Since the LF80 series blends in with almost any surroundings and the screen is nearly filled with images, this display has a powerful, eye-catching impact.
Performance with 700 cd/m2 of brightness is required for some signage and other professional applications. This allows images to be beautifully displayed even in large, brightly lit spaces, such as train stations and airports.
There is very little change in color, compared with the VA panel, when the screen is viewed at right or left angles, so the images are crisp and clear. This is ideal for providing correct information to places with a lot of people present, such as public spaces and facilities.
  • Featuring industrial durability and reliability, as well as a stylish sppearance
  • High brightness for displaying easy-to-see content in bright places
  • The IPS panel has a wide viewing angle and minimal color fluctuations
  • Choose the installation to match your application
    The LF80 series is designed for use in either portrait or horizontal orientation with no effect on panel color and lifespan, further reducing TCO. A tilt installation up to 45 degrees forward or backward is also possible. The angle can be adjusted for easy viewing when installed in a high location.
  • USB media player for simple signage use without an STB
    The LF80 series features a USB media player. Signage operation is possible by simply inputting the desired content via USB, eliminating the need for a set-top box. Both videos and still images can be displayed, so a wide variety of original signage content can be used.
Panasonic TH-49LF80W LF80 - 49" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
49"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Input lock, button lock, remote control user level
Settings Cloning Capability
Picture Enhancements
Colour Enhancement, Colour Refiner
Speaker System
2 speakers
USB
Remote control, 2 AAA batteries, 3 clampers
Voltage
AC 230V (50/60 Hz)
175 Watt
Power Consumption (On mode)
130 W
Power Consumption Stand by
0.5 Watt
109.3 cm x 7.2 cm x 62.3 cm
19 kg
175 Watt
130 W
Diagonal Class
49"
Commercial Use
Series
LF80
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, 1:1 Pixel Mode, Dynamic Picture Mode
Dimensions
Without stand
109.3 cm
7.2 cm
62.3 cm
19 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Coating
Anti-glare
Image Contrast Ratio
1300:1
Dynamic Contrast Ratio
50000:1
Brightness
700 cd/m²
Widescreen Modes
Zoom
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Backlight Life
60,000 hour(s)
Commercial Features
Certified for 24/7 Continuous Operation, MPEG Noise Reduction, Input Search Function, Fail Back
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 1280 x 720, 852 x 480, 1152 x 870, 1360 x 768, 640 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1066 x 600, 1400 x 1050, 1600 x 900
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Fast Ethernet
Supported Consumer Electronics Control (CEC)
PJ Link
Connector Type
Serial output , Serial input , Infrared input , Infrared output , VGA input , 2 x audio line-in , Composite video / component video input , Audio line-out , LAN , 2 x HDMI input , DVI-D input , DVI-D output , USB 2.0
IEC 60950-1, EN 61000-3-3:2013, EN 55024:2010, EN 55022:2010 Class A, AS/NZS CISPR 22:2009
Power supply
Input Voltage
AC 230V (50/60 Hz)
0.5 Watt
Power Consumption Sleep
0.3 Watt
Power on delay
Width (Shipping)
130.8 cm
Depth (Shipping)
20.3 cm
Height (Shipping)
84.6 cm
Weight (Shipping)
26 kg
20 - 80% (non-condensing)
