Philips 75BDL3050Q 75" 3840x2160 8ms VGA HDMI DisplayPort IPS LED Large Format Display
Quicklinx: FFBZWS00 Mfr#: 75BDL3050Q/00
Deliver startlingly clear images in a more eco-friendly way with the Q-Line display. High on performance and reliability, yet low on power consumption, it is ideal for projects where no compromise is accepted.
  • CMND
    A robust display management platform, CMND puts the power back into your hands. Update and manage content with CMND & Create or control your settings with CMND & Control. It's all possible with CMND.
  • CMND & Control
    With CMND & Control, easily manage multiple displays in a central location. With real time display monitoring, setting and software updates from a remote location, and the ability to customize and configure multiple displays at once, such as video wall or menu board displays, controlling your suite of displays has never been easier.
  • CMND & Create
    Design and create compelling content with CMND & Create, a powerful authoring tool With a drag and drop interface, preloaded templates, and integrated widgets, you'll be able to amaze your customers with compelling content.
  • SmartPlayer
    Turn your USB into a true cost effective digital Signage device. Simply save your content video, audio, pictures on your USB and plug into your display. Create your playlist and Schedule your content via the on screen menu and enjoy your own created playlists anytime anywhere.
Philips 75BDL3050Q Q-Line - 75" Class (74.52" viewable) LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
75"
Diagonal Size
74.52"
Commercial Use
Yes - digital signage
Platform
Android
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
480/60p, 720/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 2160/30p, 480/30p, 1080/30i, 2160/50p, 2160/60p, 1080/25i, 480/30i, 576/25i, 576/25p
Max Number of Screens
150
Video Interface
HDMI
HDMI Ports Qty
4 ports
LAN
PC Interface
VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
HTML5 support, CMND management
Picture Enhancements
Colour temperature adjustment, Noise Reduction, dynamic contrast enhancement, Pixel Shift, Colour Enhancement, 3D Digital Comb Filter
Speaker System
2 speakers
Storage Drive Capacity
8 GB
Storage Capacity
8 GB
Supported Memory Cards
microSD
USB
2 ports
Remote control, batteries
Voltage
Energy Class
Class B
Power Consumption (On mode)
237 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
346 kWh
167.66 cm x 7.38 cm x 95.5 cm
53.3 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class B
237 W
346 kWh
Diagonal Class
75"
Diagonal Size
74.52"
Commercial Use
Series
Q-Line
Platform
Android
Operating System
Android OS 5.1
Video Processor
Quad-Core
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
4 ports
PC Interface
Modes
Landscape mode
Dimensions
Without stand
167.66 cm
7.38 cm
95.5 cm
53.3 kg
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1200:1
Brightness
410 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Multilingual
Backlight Life
50,000 hour(s)
Commercial Features
3D MA deinterlacing, Smart Insert
Video Wall
150
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 1920 x 1080, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, ASF, AVI, MKV, MOV, VOB, FLV, TS, DAT, TRP, WebM, MPG, MPEG
Supported Audio Formats
MP3, WMA, AAC, M4A
Supported Pictures Formats
BMP, JPG, PNG, JPEG
microSD
USB Port
USB Ports Qty
2
Configuration
8 GB
8 GB
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
DisplayPort input , VGA input , 4 x HDMI , Audio line-in , Audio line-out , Serial input , Serial output , Infrared input , Infrared output , LAN , Audio line-in , 2 x USB 2.0
Batteries
HDMI cable , IR extender cable - 1.8 m , Serial cable
FCC Class B certified, UL, BSMI, cUL, CB, CCC, PSB, EMF, EAC
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Input Voltage
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
