Samsung QB43R 43" 3480x2160 HDMI LED Large Format Display
Quicklinx: F9RJWS00 Mfr#: LH43QBREBGCXEN
As visual display technology evolves, viewers develop heightened expectations about picture quality. As Ultra HD resolution continues to grow in popularity, it is essential for businesses to deliver superb picture quality for their customers. While much content is still being produced at a lower resolution, Intelligent Ultra HD upscaling technology helps Samsung's 4K Ultra HD signage increase low resolution content to Ultra HD picture quality.
  • Ultra HD 4K resolution
    Samsung's QBR series is able to hook customer attention by providing an incredibly clear picture, showcasing lifelike images and intricate details better than ever before thanks to ultra-high definition 4K resolution.
  • Intelligent Ultra HD upscaling
    Samsung has developed its powerful video processor for use in its digital signage. Additionally, intelligent Ultra HD upscaling technology is an advanced solution based on Samsung's proprietary intelligent Ultra HD engine that allows content developed at a lower resolution to be elevated to Ultra HD-level quality. It also performs edge restoration and noise reduction to optimize on-screen text and imagery with crisp edges and fine detail.
  • Dynamic Crystal Color
    Dynamic Crystal Color is what brings the incredible, lifelike color to Samsung displays. Using 10-bit processing, the display is able to showcase a wider spectrum of colors - up to a billion different shades - capturing subtle differences for flawless color expression, critical for businesses in ensuring brand consistency across communication channels. Samsung 4K Signage QBR series also features HDR10+ functionality that converts standard definition (SDR) content to HDR quality for sharper contrast and more vivid colors.
  • Slim and symmetrical design
    The slim and symmetrical design of the QBR series vastly simplifies wall mounting the display and ensures that installation is a seamless process. The display's power inlet direction has been redesigned to perfectly align against the wall.
  • Clean cable management
    With QBR's cable guide feature, retailers are able to tuck away messy cables from view. This allows for a clean and visually-appealing shopping experience for customers, even when the back of the display is visible.
  • Wi-Fi and Bluetooth built-in
    Built-in Wi-Fi and Bluetooth allow for more personalized and interactive services as well as simplifying how businesses showcase content. Whether it's to make networking simpler or enabling interactive beacon technology in-store, QBR series displays help businesses move into the future of retail.
Samsung QB43R QBR Series - 43" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/355479
Diagonal Class
43"
Commercial Use
Yes - digital signage
Platform
Tizen OS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
HDR Format
HDR10+
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN, Bluetooth
PC Interface
DVI
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform
Picture Enhancements
Mega Dynamic Contrast Ratio, UHD Upscaling, Dynamic Crystal Color
USB
2 ports
Voltage
Energy Class
Class G
110 Watt
Power Consumption (On mode)
67 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
98 kWh
96.75 cm x 4.83 cm x 55.77 cm
10 kg
Energy Class
Class G
110 Watt
67 W
67 kWh/1000h
98 kWh
Diagonal Class
43"
Commercial Use
Series
QBR Series
Platform
Tizen OS
Operating System
Tizen OS 4.0
HDR Capable
HDR Format
HDR10+
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI
Design
Narrow Bezel Design, Slim Design, New Edge Design
Dimensions
Without stand
96.75 cm
4.83 cm
55.77 cm
10 kg
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Coating
0.02% Glass Haze
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
VESA Compatibility
Media Player
USB Port
USB Ports Qty
2
Network & Internet Multimedia
Connector Type
2 x HDMI input , DVI-Digital , 2 x USB , Audio line-in , Infrared input , Audio line-out , RS-232 input , RS-232 output , LAN
UL, VCCI, C-Tick, BSMI, GOST, cUL, NOM, SASO, CB, FCC Part 15 B, AS/NZS 60950-1, CCC, EMC, PSB, IRAM, EN 60950-1, KC, AS/NZS, NOM-019-SCFI-1998, K60950-1, EAC, NOM-001-SCFI-1993 IRAM, RCM, IS13252, GB 17625.1-2012, BIS, INMETRO, IEC60950-1, GB 4943.1-2011, KN32, KN35, KCC/EK, CNS 14336-1, CISPR 32:2015, RoHS CNS 15663, CISPR 32:2016, GB/T9254-2008, CNS 13438 ITE EMI, ROCT CISPR 24-2013, ROCT CISPR 22:2005
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
109.5 cm
Depth (Shipping)
15.1 cm
Height (Shipping)
67.6 cm
Weight (Shipping)
13.3 kg
10 - 80% (non-condensing)
