The NewStar desk mount FPMA-D935G allows you to attach a LCD/TFT screen up to 26" on a desk. With this mount you can easily swivel, tilt and rotate the monitor. It has 3 pivots. The height adjustment of 50 cm can be changed manually. The desk mount can hold screens up to 12 kg and is attached on a desk by a grommet. The arm length is 50 cm. This model is suited for all LCD/TFT screens with a VESA 75x75 or 100x100 mm hole pattern. By using an ergonomic monitor arm you prevent neck- and back complaints. Ideal for use in offices and on counters or receptions.
- NewStar Full Motion Desk Mount (grommet) for 10-30" Monitor Screen, Height Adjustable - Silver - adjustable arm (Tilt & Turn)
- Product Type
- Adjustable arm (Tilt & Turn) - desk-mountable
- Adjustable Depth
- 12-50 cm
- Adjustable Height
- 0-50 cm
- Tilt
- 180°
- Pan
- 360°
- Rotation
- 360°
- Joints Qty
- 4
- Recommended Use
- LCD display
- Recommended Display Size
- Up to 30"
- Flat Panel Mount Interface
- Up to 100 x 100 mm, from 75 x 75 mm
- Max Load Weight
- 12 kg
- Silver
- 5 years warranty
- Adjustable Depth
- 12-50 cm
- Adjustable Height
- 0-50 cm
- Silver
AV Furniture
- Adjustable arm
- Design
- Tilt & Turn
- Recommended Use
- LCD display
- Placing / Mounting
- Desk-mountable
- Up to 30"
- Tilt
- 180°
- Pan
- 360°
- Rotation
- 360°
- Joints Qty
- 4
- Max Load Weight
- 12 kg
- Adjustable height, adjustable depth, rotating, swivel adjustment
- Limited warranty - 5 years
