NewStar Mobile Flatscreen Floor Stand/Trolley 32-70"
Quicklinx: B1G9WS00 Mfr#: PLASMA-M2000E
Hurry, only 1 left in stock!
£570.50 ex VAT
£684.60 inc VAT
The NewStar PLASMA-M2000E is a mobile floor stand for LCD/Plasma flatscreens up to 70" (175 cm). With this product on wheels you have perfect flexibility to place the flatscreen where ever you want. A shelf for a notebook or DVD player is included. The height can be adjustment between 115-185 cm. Cables can be placed in the column. Suited for flatscreens between 32-70" with a maximum weight of 125 kg and a maximum VESA hole pattern of 870x620 mm. Perfect for exhibitions, presentation rooms, class rooms and hospital!
Neomounts by Newstar PLASMA-M2000E - cart
Cart
Adjustable Height
115-185 cm
Tilt
15°
Adjustments
Height, tilt
Recommended Use
Flat panel / AV system
Recommended Display Size
37"-85"
VESA Mounting Interface
From 200 x 200 mm, up to 870 x 620 mm
Max Load Weight
125 kg
Wheels Qty
4
5-year warranty
Adjustable Height
115-185 cm
AV Furniture
Cart
Recommended Use
Shelf Qty
1
Cable Management
Integrated cable management
37"-85"
Tilt
15°
Adjustments
Height, tilt
Max Load Weight
125 kg
Wheels Qty
4
VESA mount adjustable height (115 - 185 cm)
Limited warranty - 5 years
Brand: NewStar
Price Range Ex VAT: £500 - £750
Stock Status: In stock
