The NewStar PLASMA-W240, allows you to mount a LED/LCD/Plasma TV to any wall. Cause of the flexible hole pattern of this system is this wall mount useable for almost every TV up to 52 inches. This wall mount allows users to tilt screens up to 20 degrees. This wall mount is easily to install by using the VESA hole pattern at the rear side of your TV. This wall mount can be used when the maximum distance between the holes (left to right) is 40 cm. The upper and lower holes allow a maximum distance of 40 cm. The PLASMA-W240 is made of aluminum and is mountable to any wall. Including security lock.
Versatile mounting options
Designed for flexibility, the Neomounts PLASMA-W240 bracket supports flat panels ranging from 23" to 60", accommodating a wide array of display sizes for a perfect fit in any space. -
Enhanced viewing experience
With up to 25° of tilt adjustment, this bracket offers optimal viewing angles, reducing glare and enhancing the audience's viewing comfort, whether it's for home entertainment or public displays. -
Robust design
Capable of supporting flat panels weighing up to 50 kg, the PLASMA-W240 is built for durability and reliability, ensuring your display stays securely mounted. -
Universal compatibility
Featuring a flat panel mount interface that ranges from 75 x 75 mm to 400 x 400 mm, this bracket is compatible with a vast range of TV sizes and brands, making it a versatile choice for any installation.
- Neomounts PLASMA-W240 bracket - tilt - for flat panel - black
- Product Type
- Bracket (tilt) - wall-mountable
- 5.9 cm
- Tilt
- 25°
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 23"-60"
- VESA Mounting Interface
- Up to 400 x 400 mm, from 75 x 75 mm
- Max Load Weight
- 50 kg
- Black
- Package Content
- Padlock
- 5-year warranty
- 5.9 cm
- Black
- Package Content
- Padlock
AV Furniture
- Bracket
- Design
- Tilt
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 23"-60"
- Tilt
- 25°
- Adjustments
- Tilt
- Max Load Weight
- 50 kg
- Limited warranty - 5 years
