NewStar Flatscreen Desk Mount 10-24"
Quicklinx: B41RWS00 Mfr#: FPMA-D400
£44.13 ex VAT
£52.95 inc VAT
The NewStar desk mount FPMA-D400 allows you to attach a LCD/TFT screen up to 24" on a desk. With this mount you can easily swivel, tilt and rotate the monitor. The height adjustment is 40 cm. The desk mount can hold screens up to 10 kg and is attached on a desk by a desk clamp. The arm length is 34 cm. Cables can be placed in the column. This model is suited for all LCD/TFT screens with a VESA 75x75 or 100x100 mm hole pattern. By using an ergonomic monitor arm you prevent neck- and back complaints. Ideal for use in offices and on counters or receptions.
  • Versatile adjustments
    With depth, height, rotation, swivel, and tilt adjustments, the Neomounts FPMA-D400 offers flexibility. This full-motion mounting kit ensures the perfect viewing angle for any LCD display sized 10"-30", enhancing user comfort and screen visibility.
  • Seamless cable management
    The integrated cable management system keeps cables neatly organized and out of sight, promoting a cleaner, more professional workspace. This feature not only enhances the aesthetic appeal of your setup but also reduces clutter and potential distractions.
  • Robust compatibility
    Designed to support LCD displays ranging from 10" to 30" and accommodating flat panel mount interfaces from 75 x 75 mm up to 100 x 100 mm, the FPMA-D400 is a versatile solution for a wide range of setups. Its ability to handle up to 10 kg ensures reliability for a variety of display types.
Neomounts FPMA-D400 mounting kit - full-motion - for LCD display - grey
Mounting kit (full-motion) - clamp mountable, desk-mountable
Adjustable Depth
10-34 cm
Adjustable Height
0-40 cm
Tilt
180°
Rotation
270°
Swivel
270°
Adjustments
Height, tilt, swivel, rotation, depth
Recommended Use
LCD display
Recommended Display Size
10"-30"
VESA Mounting Interface
Up to 100 x 100 mm, from 75 x 75 mm
Max Load Weight
10 kg
Grey
5-year warranty
Adjustable Depth
10-34 cm
Adjustable Height
0-40 cm
Grey
AV Furniture
Mounting kit
Design
Full-motion
Recommended Use
LCD display
Placing / Mounting
Clamp mountable, desk-mountable
Cable Management
Integrated cable management
10"-30"
Tilt
180°
Rotation
270°
Swivel
270°
Adjustments
Max Load Weight
10 kg
Adjustable height, rotating
Limited warranty - 5 years
Brand: NewStar
