NetGear XS712T 12-port 10-Gigabit ProSAFE Smart Switch
LIFETIME WARRANTY
Quicklinx: 8MVSWS00 Mfr#: XS712T-100NES
The XS712T is a powerful Smart Managed Switch that includes 12 ports of 10-Gigabit connectivity (12 copper with 2 shared combo copper/SFP+ Fiber ports). NETGEAR's 10-Gigabit Smart Managed Switches are purposely designed as a cost-effective way to provide 10G connections to 10G-capable servers and NAS (Network Attached Storage) systems. The XS712T provides comprehensive L2+/Layer 3 Lite features (including IPV6 management) allowing SMB customers to deploy virtualization, cloud-based services and applications like VoIP, video streaming and IP surveillance, which require higher reliability, speed, and performance. It can be used at the "center of a small business network" or as an aggregation/access switch in a larger organization. The XS712T is ideal for smaller workgroups that need high-bandwidth for sharing, collaborating, editing, and publishing high-density content like video or animation.
NETGEAR XS712T 12-Port 10GBase-T Gigabit Smart Managed Switch - switch - 12 ports - smart - rack-mountable
Switch - 12 ports - L2+ - smart
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
12 x 10GBase-T + 2 x shared 10 Gigabit SFP+
Performance
Switching fabric bandwidth: 240 Gbps
ACL: 100 , Virtual interfaces (VLANs): 256 , IGMP groups: 1000 , IPv4 routes: 32
MAC Address Table Size
32K entries
Jumbo Frame Support
9KB
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS
Flow control, full duplex capability, Layer 2 switching, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, reset button, Port Security, DHCP client, Energy Efficient Ethernet, dual firmware images, 2MB packet buffer, Class of Service (CoS), DiffServ Code Point (DSCP) support, 2 fans
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
AC 120/230 V
44 cm x 25.7 cm x 4.3 cm
4.04 kg
Latin America, North America, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
32K entries
Jumbo Frame Support
9KB
Routing Protocol
Static IP routing
Encryption Algorithm
SSL, TLS 1.0
Authentication Method
RADIUS, TACACS+
: 600 MHz
RAM
128 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, power, link/activity, fan
12 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+
Internal power supply
AC 120/230 V
98.2 Watt
Rack Mounting Kit
Included
MTBF
211,197 hours
cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, CB, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A
Software Included
Drivers & Utilities
44 cm
25.7 cm
4.3 cm
4.04 kg
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
8MVS C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.30
8MVS C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
8MVS C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.24
