Traditional switches are not designed to be installed in a living room, bedroom, or office desk, so usually we hide them because the design is not user-friendly - they have flashing LED lights and a bunch of cables that we don't want to see. NETGEAR tackles this problem head-on with the industry's first consumer-friendly switch with integrated cable management. The 900 Series switches are the first switch that you want to display! Thanks to the stylish design and the built-in cable organizer, you will keep your office and home neat and tidy. Moreover the LED ON/OFF button will keep your environment quiet so no light will disturb your movie, work or sleep
Integrated cable management
Keeps your office and home neat and tidy, with organized cables. -
Silent and invisible
Innovative, fanless design with an on/off LED light button.
- NETGEAR GS908 - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 1000Base-T
- Performance
- Bandwidth: 16 Gbps , Packet forwarding rate: 11.9 Mfps , Latency (10 Mbps): < 76.9 µs , Latency (100 Mbps): < 9.1 µs , Latency (1000 Mbps): < 2.7 µs
- Capacity
- Multicast groups: 128 , Priority queues: 4
- MAC Address Table Size
- 4K entries
- Jumbo Frame Support
- 9000 bytes
- Jumbo Frames support, fanless, on/off switches, power-saving mode, cable management, Energy-Efficient Ethernet (EEE)
- IEEE 802.3az
- Power
- AC 120/230 V (50 - 60 Hz)
- 23.4 cm x 16.4 cm x 3.3 cm
- 370 g
- Localisation
- United Kingdom
- 3-year warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 1000Base-T
- Performance
- Capacity
- 4K entries
- 9000 bytes
- IEEE 802.3az
- Status Indicators
- Power, link/activity/speed
- 8 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Installed Qty
- 1
- Voltage Required
- Included Accessories
- Wall mounting kit, cable retention strap
- Plug and Play, UL 60950-1, EAC, CNS 13438, EN 55024:2010, FCC CFR47 Part 15 B Class B, EN55022:2010 + AC:2011 Class A, VCCI V-4/2012.04, VCCI V-3/2015.04 Class A, ANSI C63.4-2014, AS/NZS 60950-1:2015, EN 61000-3-2:2014 Class A, IEC60950-1:2005, Second edition + A1:2009 + A2:2013, ICES-003:2016 issue 6 Class B, EN 6100-3-3:2013, AS/NZS CISPR22:2009+A1:2010 Class B, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- United Kingdom
- 23.4 cm
- 16.4 cm
- 3.3 cm
- 370 g
- Limited warranty - 3 years , Technical support - 90 days
- 0 °C
- 40 °C
- 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
