The ProSAFE S3300 52PT Gigabit Stackable Smart Switch is a L2+ web based platform: non-PoE in a 48 port configuration. 4 dedicated 10G ports are included as standard (2 x 10GBase-T and 2 x SFP+) for stacking and/or uplinks to aggregation layers or storage and server connections.
Enhanced connectivity
With 48 10/100/1000 RJ-45 ports alongside 2 10GBase-T and 2 10Gb Ethernet SFP+ ports, this NETGEAR Smart S3300-52X switch offers a wide range of connection options for diverse networking needs, ensuring high-speed and reliable connectivity for all connected devices. -
Robust security features
Equipped with Access Control List (ACL) support, DHCP snooping, Dynamic ARP Inspection (DAI), and IP source guard, the NETGEAR Smart S3300-52X provides comprehensive security measures to protect against unauthorized access and network threats, maintaining a secure networking environment. -
Optimized network performance
Features such as Quality of Service (QoS), Weighted Round Robin (WRR) queuing, and bandwidth capacity of 176 Gbps ensure efficient traffic prioritization and management, delivering optimized network performance and enhancing the overall user experience. -
Advanced management capabilities
Manageable via CLI, HTTP, HTTPS, SNMP, and RMON, the NETGEAR Smart S3300-52X offers versatile management options for network administrators, enabling easy setup, monitoring, and maintenance of the network infrastructure. -
Durable and reliable
With a Mean Time Between Failures (MTBF) of 279,970 hours and a rack-mountable form factor, this switch is designed for longevity and easy integration into existing network racks, providing a reliable networking solution for businesses of all sizes.
- NETGEAR Smart S3300-52X - switch - 52 ports - smart - rack-mountable
- Switch - 52 ports - smart - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 2 x 10Gb Ethernet + 2 x 10Gb Ethernet SFP+
- Performance
- Bandwidth: 176 Gbps
- Capacity
- VLANs supported: 256 , ACL entries: 100 , IPv4 routes (static): 32 , DHCP snooping entries: 8000 , ARP entries: 512 , Forwarding table entries (Multicast): 512 , Priority queues per port: 8
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- Static IPv4 routing
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP, CLI
- Flow control, trunking, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, ALG support, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, WRED, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, DHCP client, Energy Efficient Ethernet, dual firmware images, SPQ, CoS, IP source guard
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az, IEEE 802.1Qat, IEEE 802.1Qav, IEEE 802.1BA
- Power
- AC 100/230 V (50/60 Hz)
- 44 cm x 25.7 cm x 4.3 cm
- 3.66 kg
- Localisation
- Latin America, North America, Europe
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16K entries
- 9KB
- Max Units In A Stack
- 6
- Routing Protocol
- Authentication Method
- RADIUS, TACACS+
- Processor
- : 800 MHz
- RAM
- 512 MB
- Flash Memory
- 128 MB
- 48 x 1000Base-T RJ-45 , 2 x 10GBase-T RJ-45 uplink/stacking , 2 x 10Gbit LAN SFP+ uplink/stacking , 1 x USB 2.0 Type A
- Power Device
- Internal power supply
- Voltage Required
- 44.12 watt
- Rack Mounting Kit
- Included
- MTBF
- 279,970 hours
- CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, CCC, RoHS, FCC Part 15 A, C-Tick Class A, VCCI Class A
- Localisation
- 44 cm
- 25.7 cm
- 4.3 cm
- 3.66 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.16 |
