NETGEAR ProSafe JGS524 - Switch - 24 ports
LIFETIME WARRANTY
Quicklinx: 4DJ4WS00 Mfr#: JGS524-200EUS
The affordable price of NETGEAR’s JGS524 enables you to cost-effectively deliver Gigabit Ethernet networking speeds across your entire office network – even directly to the desktop. With up to 48 Gbps of bandwidth, this 24-port switch can send 2000 Mbps per port. Network users can take advantage of the their ability to send and receive large amounts of multimedia, image and video information in no time at all. The JGS524 is ideal for teams, departments or growing offices requiring outstanding performance at a low price.
-Gigabit speeds meet performance needs of bandwidth hungry applications. -Easy integration of 10, 100, and 1000 Mbps devices. -Automatic speed and full/half-duplex sensing on every port. -Auto Uplink™ on every port to ensure correct link for different cables. -LED’s make network monitoring easy. -Compact enough for desktop, but comes with a rack mount kit. -Compatible with PC, Macintosh, Linux and Unix operating systems.
  • Efficient cooling system
    Designed to operate within a wide temperature range, this switch ensures reliability from 0°C to 50°C, making it suitable for various environments.
  • Versatile compatibility
    With support for both Mac and PC platforms, this switch offers flexible integration options for a broad range of network setups.
  • High-speed connectivity
    Features 24 RJ-45 connectors supporting 1000Base-T for Gigabit Ethernet speeds, enabling high-speed connections and efficient network traffic management.
  • Robust design
    Includes a rack mounting kit and adheres to multiple compliance standards, including EN55024 and cUL, ensuring a durable and reliable networking solution.
  • Advanced networking features
    Boasts auto-negotiation, auto-uplink, and flow control capabilities, alongside a 48 Gbps switching capacity, to optimize network performance and efficiency.
NETGEAR JGS524v2 - switch - 24 ports - unmanaged - rack-mountable
Switch - 24 ports - unmanaged
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
Switching capacity: 48 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), QoS, Energy Efficient Ethernet, ToS
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
AC 100/230 V (50 - 60 Hz)
32.8 cm x 16.9 cm x 4.3 cm
1.65 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9KB
Status Indicators
Port transmission speed, power, link/activity
24 x 1000Base-T RJ-45
Internal power supply
17.9 watt
Rack Mounting Kit
Included
MTBF
238,872 hours
Plug and Play, cUL, EN55022, EN55024, CISPR 22, CB, CCC, UL 60950-1, EN 60950-1, KCC, FCC Part 15 A, C-Tick Class A, LVD, VCCI Class A, EAC
Europe
32.8 cm
16.9 cm
4.3 cm
1.65 kg
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 95%
4DJ4 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
4DJ4 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
