Your ports, where you want them
Today's networks have increasing numbers of devices attached to them. As wired devices proliferate, it can be difficult to easily and neatly place networked ports where you want them.
NETGEAR ProSAFE Click Switches™ address this issue head on.
These innovative Gigabit Ethernet switches come with an industry-first, bracket mounting system for easy installation. With a flexible and unique 1-2-3-4 click arrangement, it's easier than ever to enable optimal placement and cable management in locations where other switches will not go.
Vertical/side mount, Vertical/rear mount, Horizontal/side mount and Horizontal/rear mount.
- Available in either 8- or 16-Gigabit port configurations
- Slim design with internal power supplies
- Sleek cable management system
- Prioritise and manage bandwidth usage with intuitive web browser as seen on the ProSAFE Plus series
Put an end to unsightly cables and switch placement challenges. Deliver a better way for customers to put their ports, where they want them. Available now, click here for your Click Switch from authorised NETGEAR channels.
Robust performance
With a bandwidth capacity of 32 Gbps, the NETGEAR Plus GSS116E ensures efficient handling of network traffic, maintaining high-speed data transmission across all 16 ports. -
Enhanced security
Features like DoS attack prevention, DHCP client, and broadcast storm control provide a secure networking environment, safeguarding your data from unauthorized access and network disruptions. -
Versatile connectivity
Supporting up to 128 virtual interfaces (VLANs) and layer 2 multicast groups, this switch offers flexible configuration options to meet diverse network requirements. -
Energy efficient
Incorporating ENERGY STAR Efficient Ethernet and a fanless design, the GSS116E operates with reduced power consumption and minimal noise, making it an eco-friendly addition to any setup. -
Durable and reliable
Housed in a sturdy metal case and boasting an impressive MTBF of 721,479 hours, the NETGEAR Plus GSS116E is built to last, ensuring long-term network reliability and performance.
- NETGEAR Plus GSS116E - switch - 16 ports - Managed
- Switch - 16 ports - Managed
- Ports
- 16 x 10/100/1000
- Performance
- Bandwidth: 32 Gbps
- Capacity
- Virtual interfaces (VLANs): 128 , Layer 2 multicast groups: 128
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Remote Management Protocol
- TFTP
- Flow control, network monitoring, trunking, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, store and forward, Broadcast Storm Control, full duplex mode, vertical mounting, TFTP support, QoS, horizontal mounting, Jumbo Frames support, fanless, LACP, DHCP client, Energy Efficient Ethernet, loop prevention, Multicast filtering function, tagged VLAN, 4MB packet buffer, metal housing, ToS, DSCP support
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3az
- 7 cm x 40.7 cm x 3.5 cm
- 1.3 kg
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop
- Ports
- 16 x 10/100/1000
- Performance
- Capacity
- 8K entries
- 9KB
- TFTP
- Status Indicators
- Port transmission speed, power, link/activity
- 16 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- 8.4 watt
- Included Accessories
- Cable retaining straps, 1-2-3-4 mounting kit
- MTBF
- 721,479 hours
- VCCI, C-Tick, cUL, EN 60950, EN55022, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, CISPR 22, EN50082-1, CCC, FCC Part 15
- Localisation
- Europe
- Software Included
- Drivers & Utilities
- 7 cm
- 40.7 cm
- 3.5 cm
- 1.3 kg
- Limited warranty - lifetime , Limited warranty - power supply - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
