FS105 is an unmanaged switch with five 10/100Mbps ports in a metal case and v3 means Version 3.
Efficient connectivity
The NETGEAR FS105v3 offers seamless integration into existing networks with compatibility for both Mac and PC, ensuring a versatile solution for diverse environments. -
Robust design
Designed for durability and convenience, this switch can be placed on a desktop or mounted on a wall, providing flexibility in setup according to space and usage requirements. -
Optimized network performance
With a MAC Address Table Size of 2K entries and support for IEEE 802.3x flow control, the FS105v3 ensures efficient handling of network traffic, minimizing congestion and improving data flow. -
Simple setup
Featuring 5 RJ-45 connectors for 100Base-TX, the FS105v3 allows for quick and easy expansion of your network without the need for complex configuration, making it an ideal choice for small to medium-sized businesses. -
Reliable operation
The external power adapter and built-in status indicators for link/activity and power provide a reliable operation, ensuring your network remains active and monitored.
- NETGEAR FS105v3 - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- Performance
- Bandwidth: 1 Gbps
- MAC Address Table Size
- 2K entries
- Flow control, auto-sensing per device, store and forward, 64KB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x
- Power
- AC 120/230 V (50/60 Hz)
- 10.1 cm x 9.4 cm x 2.7 cm
- 260 g
- Localisation
- United Kingdom
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- Performance
- Bandwidth: 1 Gbps
- 2K entries
- Status Indicators
- Port status, power, link/activity
- 5 x 100Base-TX RJ-45
- Power Device
- External power adapter
- Voltage Required
- Included Accessories
- Wall mounting kit
- MTBF
- 4,200,000 hours
- C-Tick, cUL, EN 60950, UL 1950, FCC Part 15 Class B, IEC 950, EN 55022/CISPR 22 Class A, RU EAC
- Localisation
- United Kingdom
- 10.1 cm
- 9.4 cm
- 2.7 cm
- 260 g
- Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 2 years , Technical support - lifetime
- 0 °C
- 40 °C
- 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
