The GS516TP Gigabit Smart Switch is a state-of-the-art, high-performance, IEEE-compliant network solution designed for users who require many ports and want the power of gigabit connectivity to eliminate bottlenecks, boost performance, and increase productivity. The front panel of the switch has 16 twisted-paired ports that support nonstop 10/100/1000 networks.
Enhanced connectivity
With 16 Gigabit Ethernet ports, including 8 PoE (Power over Ethernet) ports, the NETGEAR GS516TP offers versatile connectivity options for a wide range of devices, ensuring efficient power and data delivery over a single cable. -
Robust security features
Equipped with Access Control List (ACL) support, the switch provides enhanced network security, allowing for detailed control over network traffic and preventing unauthorized access. -
Energy efficient
Featuring ENERGY STAR and an internal power supply, this switch is designed to optimize power usage, reducing operational costs while maintaining high performance. -
Advanced management capabilities
The NETGEAR GS516TP is manageable, offering features such as Quality of Service (QoS) and MLD snooping, enabling prioritized data flow and improved network efficiency. -
Flexible installation options
This switch's form factor allows for both desktop and rack-mountable setups, providing flexibility in installation to meet the spatial constraints and requirements of any networking environment.
- NETGEAR GS516TP - switch - 16 ports - Managed - rack-mountable
- Switch - 16 ports - L3 Lite - Managed
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 (PoE) + 8 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 76 W
- Performance
- Bandwidth: 32 Gbps
- Capacity
- Static routes: 32 , Layer 2 multicast groups: 1000 , DHCP snooping entries: 1024
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3, MLDv2, MLD
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP
- Flow control, auto-sensing per device, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, TFTP support, ACL support, QoS, MLD snooping, LLDP support, Port Security, DHCP client, Energy Efficient Ethernet, CoS, 8MB packet buffer, 802.1x authentication, ToS, VoIP support, DSCP support, administrator's password
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
- 32.8 cm x 16.9 cm x 4.3 cm
- 2.213 kg
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 76 W
- Performance
- Capacity
- 8K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- SSL, TLS 1.0
- Authentication Method
- RADIUS, TACACS+
- Status Indicators
- Port transmission speed, power, PoE, link/activity, fan
- 8 x 1000Base-T RJ-45 PoE , 8 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- 92.1 watt
- Rack Mounting Kit
- Included
- MTBF
- 479,350 hours
- CSA, cUL, EN 60950, IEC950, UL 1950, EN55024, EN55022 Class A, CISPR 22, EN50082-1, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A, TLS v1.0
- Localisation
- Europe
- Software Included
- Drivers & Utilities
- 32.8 cm
- 16.9 cm
- 4.3 cm
- 2.213 kg
- 0 °C
- 50 °C
- 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
