The ProSafe FS116P provides power and data from a single point, using Power over Ethernet (PoE) over a single Cat-5 cable. The sixteen Fast Ethernet ports can be used for any 10/100 Mbps link and eight of these ports can supply industry-standard IEEE 802.3af power. Advanced auto-sensing algorithm gives power only to 802.3af end devices, so no need to worry about damaging proprietary PoE or non-PoE equipment. In addition, it discontinues the power when PoE devices are disconnected. Easy and reliable, the ProSafe FS116P automatically determines PoE requirements, speed, duplex, and cable type using AutoUplink.
The affordably priced ProSafe FS116P delivers PoE to any small business network that wants to simplify the installation of wireless access points and IP-based surveillance cameras. These devices are optimally installed on a ceiling or high on a wall, away from most electrical outlets. PoE eliminates the requirement for a dedicated electrical outlet to power these devices. This allows for flexibility in situating devices where AC power is difficult to access and lowers installation costs. Compact and flexible, the ProSafe FS116P is ideal for small business network that want to inexpensively use PoE to deploy wireless access points and IP-based network surveillance cameras.
Choose to plug in up to eight Ethernet or Fast Ethernet devices and mix in up to four 802.3af IP-based devices like wireless access points or IP-based network surveillance cameras. Place these 802.3af-compliant devices where they belong - high up on walls and ceiling for maximum coverage - or anywhere else you need them. Power and data are carried over standard Cat-5 cabling.
The standards-based ProSafe FS116P senses and adjusts for network speed and cabling type automatically, for easy integration into your existing 10/100 Ethernet network. For PoE, the switch automatically detects 802.3af-compliant devices, and supplies power as needed. Front panel LEDs keep you informed of switch and PoE status.
Engineered for compact convenience, it is only 1-inch high and 4-inches deep, with a durable metal case that is easily positioned on your desktop or a wall, using the included mounting hardware. The fan-less design quietly integrates in your small office environment.
With data switching and Power over Ethernet integrated into one unit, the FS116P saves space, reduces cables and eliminates the requirement for dedicated electrical outlets - lowering installation costs, simplifying installation of PoE-capable devices, and eliminating the need for electricians or extension cords. All in all a great benefit for a modest price.
Robust performance
With a bandwidth of 3.2 Gbps, the NETGEAR FS116Pv2 ensures smooth and efficient network traffic handling, making it suitable for businesses requiring reliable data transmission. -
Enhanced connectivity
Featuring 16 RJ-45 connectors with Power over Ethernet (PoE) support, this switch facilitates the deployment of network devices such as IP cameras and VoIP phones by eliminating the need for additional power supplies. -
Durable and reliable
Designed to operate in a wide range of environmental conditions, the NETGEAR FS116Pv2 boasts an impressive MTBF of 546,673 hours, ensuring long-term reliability and performance. -
Energy efficient
Incorporating Energy-Efficient Ethernet (EEE) technology, the switch reduces power consumption without sacrificing performance, making it an eco-friendly choice for your network infrastructure. -
Flexible installation options
The compact form factor of the NETGEAR FS116Pv2 allows for desktop or wall-mounted installation, providing flexibility in setup based on your spatial requirements and preferences.
- NETGEAR FS116Pv2 - switch - 16 ports - unmanaged
- Switch - 16 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100 (PoE)
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 70 W
- Performance
- Bandwidth: 3.2 Gbps
- MAC Address Table Size
- 8K entries
- Auto-sensing per device, EEE, flow control, store and forward
- IEEE 802.3af, IEEE 802.3i, IEEE 802.3u, IEEE 802.1p, IEEE 802.3x
- 28.6 cm x 10.2 cm x 2.7 cm
- 830 g
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Fast Ethernet
- Ports
- 16 x 10/100 (PoE)
- PoE
- PoE Budget
- 70 W
- Performance
- 8K entries
- Status Indicators
- Power, PoE, link/activity/speed
- 16 x 100Base-TX RJ-45 PoE
- Power Device
- External power adapter
- 80 watt
- Included Accessories
- Wall mounting kit
- MTBF
- 546,673 hours
- Plug and Play, IEEE 802.3az, FCC Part 15 A, VCCI Class A, EN 55022/CISPR 22 Class A, C-Tick Class A, EN55024, EN 60950, LVD
- Localisation
- Europe
- 28.6 cm
- 10.2 cm
- 2.7 cm
- 830 g
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
- 0 °C
- 40 °C
- 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
