The NETGEAR S350 series Gigabit Ethernet switches provide comprehensive L2 features to ensure a reliable and secured network for SMB customers to deploy applications like VoIP, video and IP surveillance. The cost-effective S350 series provides easy-to-manage and highly secured network solution to your business with advanced features. With fanless design, the switch will operate quietly, perfect for the noise-sensitive environment.
- NETGEAR Smart GS308T - switch - 8 ports - smart
- Switch - 8 ports - smart
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Routing Protocol
- IGMP
- Remote Management Protocol
- SNMP
- VLAN support, IGMP snooping, STP support, DHCP snooping, ACL support, QoS, fanless, LACP support, LACP, Energy Efficient Ethernet, rate limit, security slot (Kensington security lock compatible)
- IEEE 802.3ad (LACP), IEEE 802.3az
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Routing Protocol
- IGMP
- SNMP
- Status Indicators
- Power, reset
- 8 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - web support
