NETGEAR Pro GS308T 8-port Smart Switch
Quicklinx: F1ZPWS00 Mfr#: GS308T-100UKS
The NETGEAR S350 series Gigabit Ethernet switches provide comprehensive L2 features to ensure a reliable and secured network for SMB customers to deploy applications like VoIP, video and IP surveillance. The cost-effective S350 series provides easy-to-manage and highly secured network solution to your business with advanced features. With fanless design, the switch will operate quietly, perfect for the noise-sensitive environment.
  • Efficient energy use
    The NETGEAR Smart GS308T switch is designed with Energy Efficient Ethernet (IEEE 802.3az) support, ensuring lower energy consumption without sacrificing performance.
  • Enhanced network security
    With features like Access Control List (ACL) support, DHCP snooping, and a security slot compatible with Kensington security locks, this switch offers robust security options to protect your network.
  • Optimized connectivity
    Featuring 8 1000Base-T RJ-45 ports with support for LACP, Quality of Service (QoS), and VLAN, the GS308T provides flexible and optimized connectivity options for various networking needs.
  • Quiet operation
    The fanless design of the NETGEAR Smart GS308T ensures silent operation, making it suitable for noise-sensitive environments like small offices or home offices.
NETGEAR Smart GS308T - switch - 8 ports - smart
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Routing Protocol
IGMP
Remote Management Protocol
SNMP
VLAN support, IGMP snooping, STP support, DHCP snooping, ACL support, QoS, fanless, LACP support, LACP, Energy Efficient Ethernet, rate limit, security slot (Kensington security lock compatible)
IEEE 802.3ad (LACP), IEEE 802.3az
NETGEAR lifetime warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Routing Protocol
IGMP
SNMP
Status Indicators
Power, reset
8 x 1000Base-T RJ-45
External power adapter
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - web support
