NetGear ProSafe Plus 24-Port Fast Ethernet Unmanaged Switch
LIFETIME WARRANTY
Quicklinx: B1FRWS00 Mfr#: JFS524-200EUS
Need a quantum leap in office network capability? NETGEAR delivers an effective solution--the JFS524. This unmanaged 10/100 Mbps Fast Ethernet switch provides expanded connectivity for small office networks so users no longer have to compete with each other for bandwidth. All of the essential features - automatic speed and full/half duplex sensing, 200 Mbps throughput per port, Auto Uplink are included, but at an economical price that a value-conscious business owner cannot ignore.
Frugal and Skillful
Twenty-four ports of speed and capacity at a modest price, with no compromising on quality--that's what you can expect from NETGEAR's hardworking JFS524. Switched 10/100 Mbps ports provide private bandwidth for PCs, servers, or hubs and support 200 Mbps of throughput. Each port delivers 200 Mbps of network speed in full-duplex mode.
Alert and Obliging
Ever-vigilant, the JFS524 begins to operate as soon as it's powered on - with no configuration required. All 24 ports deliver automatic speed and full/half duplex sensing, plus Auto Uplink, which adjusts for straight-through or crossover cables to make the right link. This rugged metal unit is conveniently compact for an uncluttered desktop or easy rack mounting. And it lets you easily intermix 10 and 100 Mbps devices within your unmanaged network.
Performance (64 byte packets)
Store-and-forward packet switching
Forward rate (10 Mbps) 14,800 packet per sec.
Forward rate (100 Mbps) 148,000 packet per sec.
Latency (10 to 100 Mbps) 20 usec max
MAC addresses 4,000
Queue buffer KBytes 320
Mean time between failures (MTBF): 110,000 hours (13 years)
Box Contains
ProSAFE 24-port 10/100 Fast Ethernet Switch
Rack-mount kit
Power cord
Installation guide
  • Frugal
    Twenty-four ports of speed and capacity at a modest price, with no compromising on quality - that is what you can expect from NETGEAR's hardworking JFS524.
  • Skillful
    Switched 10/100 Mbps ports provide private bandwidth for PCs, servers, or hubs, and support 200 Mbps of throughput. Each port delivers 200 Mbps of network speed in full-duplex mode.
  • Alert
    Ever-vigilant, the JFS524 begins to operate as soon as it is powered on - with no configuration required. All 24 ports deliver automatic speed and full/half duplex sensing, plus Auto Uplink, which adjusts for straight-through or crossover cables to make the right link.
  • Obliging
NETGEAR 24-Port 10/100 Fast Ethernet Switch JFS524v2 - switch - 24 ports - unmanaged - rack-mountable
Switch - 24 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
24 x 10/100
28 cm x 12.6 cm x 4.4 cm
1 kg
Europe
Enclosure Type
Desktop, rack-mountable
Subtype
Fast Ethernet
Ports
24 x 10/100
Status Indicators
Port status, power
24 x 100Base-TX RJ-45
Internal power supply
4 Watt
FCC Class A certified, CB, CCC, UL 60950-1, C-Tick Class A, VCCI Class A
Europe
28 cm
12.6 cm
4.4 cm
1 kg
50 °C
10 - 90% (non-condensing)
B1FR C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
B1FR C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
