NetGear ProSAFE Click Switch 8PT GE
LIFETIME WARRANTY
Quicklinx: B29YWS00 Mfr#: GSS108E-100EUS
Your ports, where you want them
Today's networks have increasing numbers of devices attached to them. As wired devices proliferate, it can be difficult to easily and neatly place networked ports where you want them.
NETGEAR ProSAFE Click Switches™ address this issue head on.
These innovative Gigabit Ethernet switches come with an industry-first, bracket mounting system for easy installation. With a flexible and unique 1-2-3-4 click arrangement, it's easier than ever to enable optimal placement and cable management in locations where other switches will not go.
Vertical/side mount, Vertical/rear mount, Horizontal/side mount and Horizontal/rear mount.
  • Available in either 8- or 16-Gigabit port configurations
  • Slim design with internal power supplies
  • Sleek cable management system
  • USB charging ports on GSS108E
  • Prioritise and manage bandwidth usage with intuitive web browser as seen on the ProSAFE Plus series
Put an end to unsightly cables and switch placement challenges. Deliver a better way for customers to put their ports, where they want them. Available now, click here for your Click Switch from authorised NETGEAR channels.
  • Robust performance
    With a bandwidth of 16 Gbps, the NETGEAR Plus GSS108E ensures efficient handling of network traffic, facilitating smooth data transmission across all connected devices.
  • Enhanced connectivity
    Equipped with 8 10/100/1000 ports, this switch supports auto-negotiation to provide the highest network speed for connected devices, enhancing your network's efficiency.
  • Advanced network features
    Features such as VLAN support, Quality of Service (QoS), and IGMP snooping optimize the network for reliability and performance, ensuring prioritization of critical communications.
  • Energy efficient
    Incorporating Energy Efficient Ethernet and a fanless design, the GSS108E operates quietly while reducing power consumption, making it an eco-friendly addition to any setup.
  • Durable and reliable
    A high MTBF of 1,031,177 hours, coupled with a robust set of compliance standards, ensures the GSS108E is a reliable backbone for any business network.
NETGEAR Plus GSS108E - switch - 8 ports - smart
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
Virtual interfaces (VLANs): 64 , Layer 2 multicast groups: 128
MAC Address Table Size
8K entries
Jumbo Frame Support
16KB
Remote Management Protocol
HTTP
Flow control, VLAN support, IGMP snooping, port mirroring, WRR queuing, store and forward, Broadcast Storm Control, full duplex mode, firmware upgradable, vertical mounting, TFTP support, QoS, horizontal mounting, plastic housing, fanless, DHCP client, Energy Efficient Ethernet, 2MB packet buffer, loop prevention, Multicast filtering function, CoS, tagged VLAN, ToS, DSCP support
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
30.5 cm x 6.5 cm x 3.5 cm
440 g
United Kingdom, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
8K entries
Jumbo Frame Support
16KB
HTTP
Status Indicators
Port transmission speed, power, link/activity
8 x 1000Base-T RJ-45 , 2 x USB (power only) Type A
Internal power supply
20.1 watt
Cable retaining straps, 1-2-3-4 mounting kit
MTBF
1,031,177 hours
CISPR 22 Class B, cUL, EN 60950, IEC950, UL 1950, CSA 22.2 No. 950, EN50082-1, EN55022 Class B, C-Tick Class B, FCC Part 15 B, EN55024 Class B, CCC Class B, VCCI Class B
Software Included
Drivers & Utilities
30.5 cm
6.5 cm
3.5 cm
440 g
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
B29Y C2G 2m USB 2.0 A/B Cable - Black In Stock £4.03
