The Netgear ProSafe GS510TP provides a compact solution that fits nicely into a situation where low-port density is desired for specific areas or extension of the network. It comes with 8 PoE-capable Gigabit copper ports to connect to your PoE end devices and two additional dedicated Gigabit Fiber ports for uplinks with greater distance. Plus, with the PoE Plus support, GS510TP is able to provide sufficient power for those power-hungry devices with up to 30w per port with a total power budget of 130w on the switch. GS510TP is packed with powerful features capable of enhancing any type of business network.
Power-over-Ethernet (PoE)
Provide flexibility and simplicity for your VoIP and video surveillance deployments. -
PoE Plus
Future-proof, capable of powering your 11n Wi-Fi access points as well as PTZ cameras and video phones. -
Traffic management
Prioritize traffic to ensure quality of latency-sensitive services and applications despite increasing traffic loads. -
Advanced security with 802.1x and ACL
User-based authentication and added filtering to permit or deny traffic based on MAC or IP addresses. -
Auto voice and auto video
Assist customers to easily set up VoIP or IP surveillance networks with a couple of simple steps. -
PoE power management
Automatically detect PoE on the end devices and dynamically manage power assignments and priority. -
PoE timer
Schedule to turn off your Wi-Fi network or VoIP phones outside of office hours for security and energy savings. -
Centralized management via the Smart Control Center
Discover all the Smart Switches in the network, configure them from a central location; schedule mass configuration and firmware uploads.
- NETGEAR GS510TP - switch - 8 ports - Managed - rack-mountable
- Switch - 8 ports - L3 Lite - Managed
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 (PoE) + 2 x SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 130 W
- Performance
- Bandwidth: 20 Gbps
- MAC Address Table Size
- 4K entries
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS
- Flow control, auto-sensing per device, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), LLDP support, DHCP client, Management Information Base (MIB), 512KB packet buffer, 802.1x authentication, VoIP support, DiffServ Code Point (DSCP) support, administrator's password
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at
- Power
- AC 120/230 V (50 - 60 Hz)
- 32.8 cm x 16.9 cm x 4.3 cm
- 1.68 kg
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 130 W
- Performance
- 4K entries
- Routing Protocol
- Encryption Algorithm
- MD5
- Authentication Method
- RADIUS, TACACS+
- Status Indicators
- Port transmission speed, power, PoE, link/activity, fan
- 8 x 1000Base-T RJ-45 PoE - 30 W , 2 x 1000Base-X SFP
- Power Device
- Internal power supply
- Voltage Required
- 147 Watt
- Included Accessories
- Rubber feet
- Rack Mounting Kit
- Included
- MTBF
- 458,124 hours
- C-Tick, EN55022, EN55024, CB, CCC, UL 60950-1, EN 60950-1, KCC, FCC Part 15 A, EN 61000, VCCI Class A, cUL No.60950-1, EAC
- Localisation
- Europe
- Software Included
- Drivers & Utilities
- 32.8 cm
- 16.9 cm
- 4.3 cm
- 1.68 kg
- 0 °C
- 50 °C
- 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
