NetGear ProSafe 16 Port GE PoE Smart Switch
LIFETIME WARRANTY
Quicklinx: 9196WS00 Mfr#: GS516TP-100EUS
The GS516TP Gigabit Smart Switch is a state-of-the-art, high-performance, IEEE-compliant network solution designed for users who require many ports and want the power of gigabit connectivity to eliminate bottlenecks, boost performance, and increase productivity. The front panel of the switch has 16 twisted-paired ports that support nonstop 10/100/1000 networks.
  • Enhanced connectivity
    With 16 Gigabit Ethernet ports, including 8 PoE (Power over Ethernet) ports, the NETGEAR GS516TP offers versatile connectivity options for a wide range of devices, ensuring efficient power and data delivery over a single cable.
  • Robust security features
    Equipped with Access Control List (ACL) support, the switch provides enhanced network security, allowing for detailed control over network traffic and preventing unauthorized access.
  • Energy efficient
    Featuring ENERGY STAR and an internal power supply, this switch is designed to optimize power usage, reducing operational costs while maintaining high performance.
  • Advanced management capabilities
    The NETGEAR GS516TP is manageable, offering features such as Quality of Service (QoS) and MLD snooping, enabling prioritized data flow and improved network efficiency.
  • Flexible installation options
    This switch's form factor allows for both desktop and rack-mountable setups, providing flexibility in installation to meet the spatial constraints and requirements of any networking environment.
NETGEAR GS516TP - switch - 16 ports - Managed - rack-mountable
Switch - 16 ports - L3 Lite - Managed
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE) + 8 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
76 W
Performance
Bandwidth: 32 Gbps
Static routes: 32 , Layer 2 multicast groups: 1000 , DHCP snooping entries: 1024
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP
Flow control, auto-sensing per device, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, TFTP support, ACL support, QoS, MLD snooping, LLDP support, Port Security, DHCP client, Energy Efficient Ethernet, CoS, 8MB packet buffer, 802.1x authentication, ToS, VoIP support, DSCP support, administrator's password
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
32.8 cm x 16.9 cm x 4.3 cm
2.213 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
76 W
Performance
Bandwidth: 32 Gbps
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL, TLS 1.0
Authentication Method
RADIUS, TACACS+
Status Indicators
Port transmission speed, power, PoE, link/activity, fan
8 x 1000Base-T RJ-45 PoE , 8 x 1000Base-T RJ-45
Internal power supply
92.1 watt
Rack Mounting Kit
Included
MTBF
479,350 hours
CSA, cUL, EN 60950, IEC950, UL 1950, EN55024, EN55022 Class A, CISPR 22, EN50082-1, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A, TLS v1.0
Europe
Software Included
Drivers & Utilities
32.8 cm
16.9 cm
4.3 cm
2.213 kg
50 °C
95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
