NetGear Next-Gen Edge M5300-28GF3 Managed Switch
Quicklinx: 8V3PWS00 Mfr#: GSM7328FS-200NES
NETGEAR’s family of reliable, high-performance ProSAFE Gigabit Layer 3 Stackable Switches provides maximum throughput and flexibility for demanding networks, with all the Layer 3 features you expect— and the future proofing you want. The ProSAFE GSM7328S, GSM7328FS or GSM7352S are ideal as a backbone switches, Gigabit servers, or as the robust core of a demanding, all-Gigabit network. These ProSAFE Gigabit switches can be used to inexpensively off-load routers that are segmenting your network and lay the groundwork for new IP-based services. All three switches include four hot-swappable, high-speed module bays which offer options for standards-based10G connectivity or for 48Gbps stacking within the switch family. For maximum flexibility, the GSM7328S and GSM7352S offer 24 and 48 Copper Gigabit Ports, respectively, while the GSM7328FS offers 24 SFP slots for high-density fiber deployments. The non-blocking design of the switch delivers simultaneous, full wire-speed, low-latency throughput to all ports.
Netgear Next-Gen Edge Managed Switch M5300-28GF3 - switch - 24 ports - Managed
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
24 x Gigabit SFP + 4 x shared 10/100/1000
Performance
Switching capacity: 144 Gbps , Throughput: 107.1 Mbps
224 , IP router interfaces: 128
MAC Address Table Size
8K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, CLI
Layer 3 switching, BOOTP support, ARP support, VLAN support, IGMP snooping, traffic shaping, DiffServ support, WRR queuing, store and forward, IPv6 support, sFlow, STP support, RSTP support, MSTP support, QoS, DHCP server, MLD snooping, IPv4 support, DHCP relay, LACP, GVRP, CoS
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
44 cm x 39.1 cm x 4.3 cm
6.3 kg
NETGEAR lifetime warranty
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
RADIUS, TACACS+
1: 666 MHz
RAM
256 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, power, status, RPS (Redundant Power Supply), link/activity
4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x management (RS-232) , 24 x SFP (mini-GBIC)
Expansion Slots
4 (total) / 4 (free) x Expansion Slot
Internal power supply
1 x null modem cable
Rack Mounting Kit
Included
MTBF
117,747 hours
FCC Class A certified, C-Tick, CISPR 22 Class A, cUL, EN 60950, UL 1950, VCCI Class A ITE, IEC 60950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1
44 cm
39.1 cm
4.3 cm
6.3 kg
Limited warranty - lifetime
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
8V3P C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
8V3P C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
8V3P NetGear 3m SFP+ Direct Attach Cable In Stock £99.85
8V3P NetGear Prosafe 1m Direct Attach SFP+ Cable In Stock £67.13
