Today's growing businesses rely more on their network to carry out mission-critical business activities. Deployment of VoIP and IP surveillance needs the network intelligence to separate the voice and video traffic from data, and prioritis them accordingly. However, companies do not necessarily have more money or advanced training to deal with complex managed switches.
Netgear ProSAFE Gigabit Plus Switches meet this growing need by providing fundamental network features such as VLANs, QoS, and IGMP Snooping that will help optimise the performance of business networks. ProSAFE Plus switches come in a variety of configurations, and certian models support support Power-over-Ethernet (PoE) and can power devices such as IP phones, IP surveillance cameras and wireless access points with just an Ethernet cable, making them perfect for low cost PoE deployments.
ProSAFE Plus Switches are the perfect upgrade from the plug-and-play unmanaged switch, delivering essential networking features at a very affordable price.
Box Contains
Netgear ProSAFE 8 port Gigabit Plus Switch
AC Adapter
Wallmount Kit
User Documentation/Media
Robust performance
Equipped with 8 Gigabit Ethernet ports, this NETGEAR Plus GS108PEv3 switch ensures high-speed connectivity and efficient handling of traffic, making it ideal for small to medium-sized business networks. -
Enhanced network security
Features like DoS attack prevention, broadcast storm control, and VLAN support provide a secure networking environment, safeguarding your data from unauthorized access and network disruptions. -
Optimized power management
With Power over Ethernet (PoE) support on 4 ports, the switch facilitates flexible deployment of network devices such as IP cameras and VoIP phones by eliminating the need for additional power cables. -
Intelligent traffic management
Quality of Service (QoS) feature prioritizes network traffic to ensure that critical applications receive the bandwidth they require for optimal performance. -
Easy setup and management
The desktop form factor combined with an intuitive interface allows for hassle-free installation and configuration, making network management more straightforward.
- NETGEAR Plus GS108PEv3 - switch - 8 ports - Managed
- Switch - 8 ports - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 4 x 10/100/1000 (PoE) + 4 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE
- Performance
- Bandwidth: 16 Gbps , Forwarding performance: 14.88 Mpps
- MAC Address Table Size
- 4K entries
- Flow control, Layer 2 switching, auto-sensing per device, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, wall mountable, QoS, Green Ethernet, bandwidth control
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x
- 15.8 cm x 10.1 cm x 2.9 cm
- 0.54 kg
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Performance
- 4K entries
- Status Indicators
- Port status, port transmission speed, PoE, link/activity
- 4 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE
- Power Device
- External power adapter
- EN 60950, CB
- Software Included
- Drivers & Utilities
- 15.8 cm
- 10.1 cm
- 2.9 cm
- 0.54 kg
- Limited warranty - power supply - 2 years
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £4.30 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.73 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.64 |
